Fuel door stuck?
Old 06-30-2009, 02:48 AM
valkyrie6x6's Avatar
Default Fuel door stuck?
When I bought my 2006 xB the fuel door did not open, I can hear it releasing but it does not open unless I pop it open with my key.
Should there be a spring or something so that it pops open, or opens enough that I do not have to pop it open with my key?
When I pop it open there is no rezistance when I use my key>
Thanks in advance
valkyrie6x6 is offline
Old 06-30-2009, 04:24 PM
RedneckwithanxB's Avatar
There should be a small spring on the hinge AFAIK
RedneckwithanxB is offline
Old 06-30-2009, 11:17 PM
kewlbox's Avatar
You might have to bent out the metal tab that pops the door open, i had to do that with mine.
kewlbox is offline
Old 07-01-2009, 12:05 AM
IH8ONYU's Avatar
sometimes the catch doesn't clear the catch tab, as kewlbox says, bend the tab in for clearance, but check to see if there is a pressure spring in the fuel door.
IH8ONYU is offline
Old 07-01-2009, 04:09 AM
No Spring at all, is this a dealer item?
Old 07-01-2009, 04:14 AM
draxcaliber's Avatar
well, on the tc, it isn't a coil spring, it is a "V" shaped piece of metal that the fuel door squeezes it as it closes, and the fuel door pulls in a tab that release it.
it should be attached to the hinge of the fuel door, but it just clips on and off, so maybe it fell off. check if it is there.
draxcaliber is offline
Old 07-01-2009, 04:16 AM
I just looked it is not there, so I guess I'll go to the stealer and get another.
Old 07-01-2009, 04:24 AM
http://www.trademotion.com/partlocat...=4&catalogid=2
wow...sets you back a whopping...50 cents plus shipping! probably better off paying the full .63 cents at the dealership, plus tax.
Old 07-01-2009, 04:32 AM
Thanks that's what I was looking for $9,95 for shiping is to much, I'll go to the dealer.
Old 07-01-2009, 04:35 AM
yeah, print that out and take the part number to the dealer.
i remember when i went to get a new front bumper for my tc because they won't ship large parts, the douche at the parts department quoted me a price that was $20 over msrp sparks had posted. i corrected him about this and then he suddenly played dumb going "oh, i pulled up the wrong part number, sorry!"
Old 07-01-2009, 04:38 AM
Printed it and I'll stop at the dealer tomorrow, thanks
Old 07-03-2009, 02:16 AM
I got the peice today from the Scion stealer, $7.03 This peice is not covered under the warrentty. 30 second install.
Old 06-09-2014, 06:00 AM
hawaiiguy's Avatar
can someone take a pic of the inside of a '04-'06 xb gas cap door?
my gas cap door hinge (tension pressure 1 pc thin metal/v shaped) fell off when I opened up the gas door release, and really don't know how to attach it...it seemed to be glued? to a brown plastic piece, or did a small piece of plastic break off, so that's why it doesn't appear to want to be reattached???
please, there appears to be two ways it is to be reattached, and I need to see which is the correct way...
hawaiiguy is offline
Old 08-07-2014, 09:51 PM
AKgoalie7's Avatar
Go to the dealer and re-order the part.
I had to do mine today. it's a fuel spring assembly piece (part number 77360)
Looks like this Toyota - SPRING ASSEMBLY- FUEL FILLER Part Number: 77360-52010
Cost me 5 bucks at the dealer.
AKgoalie7 is offline
ScionXa06
05-18-2015 10:05 PM
ScionLife Editor
04-01-2015 11:10 PM
mischadoll
03-09-2015 05:48 AM
Quick Reply: Fuel door stuck?
