Cracking or popping noise from the car
Old 07-08-2007, 11:24 PM
bb_ist's Avatar
Default Cracking or popping noise from the car
I dunno why but I'm hearing A LOT of cracking and popping noises from my 08 xb whenever i'm driving around.
Kinda like the sound when u turn off the car after a drive. it sounds like metal popping noise when the car is cooling down
Does anyone experience this?
bb_ist is offline
Old 07-09-2007, 12:49 AM
evosky's Avatar
maybe check your lug nuts, they might not be tightened enough ?
evosky is offline
Old 07-17-2007, 06:27 PM
BOX4MERS's Avatar
same here im hearing some sounds in the back of car, but my buddy said it could be the license plate in the back of the car when ur driving, winds will kinna moved it or something
BOX4MERS is offline
Old 07-18-2007, 11:58 PM
roXor_boXor's Avatar
Do either of you have the rear sway bar?
roXor_boXor is offline
Old 09-14-2007, 10:01 PM
JoanMarshall's Avatar
I was hearing these sounds like a piece of gravel being kicked up every once in a while and hitting the inside of the wheel well. Figured out that it was the cargo floor not locked down. Check that out.
JoanMarshall is offline
Old 09-14-2007, 10:21 PM
Team No Limitz
NoLimitzBuilt's Avatar
I hear it on mine every now and then. I have not looked into it a whole lot. I know my tC did it also. I figured I would give it a couple months and see if it still does it.
NoLimitzBuilt is offline
Old 09-17-2007, 10:54 PM
timumi's Avatar
I think I hear something every time I hit a bump while making a sharp turn.
This is after sway bar was installed.
timumi is offline
Old 09-18-2007, 12:05 AM
bb_ist's Avatar
i gotta revise the sound that I'm hearing. Its like those metal *tink* sounds when u turn off ur car after a long drive.
also, i dont have any suspension mods yet...
bb_ist is offline
Old 03-28-2008, 05:36 PM
HypnoticTealMica's Avatar
If you have the cargo cover, some noise is from those little ball weights on the tethered lift cords.
HypnoticTealMica is offline
Old 03-29-2008, 12:29 AM
whitebreadbox's Avatar
i have had the same sounds coming from the rear. check all the jacking equipment in the cargo area and make sure the spare is secure. i put padding under all the equipment back there and its helped, but its still there. (and thats with/without swaybars)
whitebreadbox is offline
Old 03-29-2008, 02:09 AM
miketf1's Avatar
i suspect it might just be gravel hitting your exhaust
ive got some stickies on and they kick up sand and gravel all the time. once driving through a sandy area i heard a similar "tink" sound and i freaked. my rear passenger pointed out it was gravel hitting the exhaust and that sounded all good to me.
miketf1 is offline
cid_mcdp
01-05-2015 02:45 PM
gularti
12-04-2014 01:21 PM
Joeynenj
11-25-2014 05:29 AM
tC_Normo
10-22-2003 07:20 PM
TheRedBox
10-21-2003 09:47 PM
Quick Reply: Cracking or popping noise from the car
