Car Audio Setup Pics required
Old 04-15-2008, 10:31 AM
chadfo's Avatar
Default Car Audio Setup Pics required
Post pics of your systems and any details about it you'd like to share.
chadfo is offline
Old 04-15-2008, 10:37 AM
chadfo's Avatar
My system:
Scion Pioneer Premium Head unit
Hifonics Brutus 1600W x 1
Hifonics Zeus 85W x 4
2 Kicker Solobaric L5 8 " subs
Diamond Audio S600S components in front
The amps are under the cover. I made it this way so I can still use the space. I still need grills for the subs.
chadfo is offline
Old 04-15-2008, 03:00 PM
Team No Limitz
NoLimitzBuilt's Avatar
Here is mine. The quick lay out of the system.
Audiovox VM9022 7” tv/ dvd/ player
Rockford Fosgate 3sixty.2 EQ
Rockford Fosgate T600-4
Rockford Fosgate T1500-1BD
Rockford Fosgate T162S front speakers
Rockford Fosgate T162C rear speakers
Rockford Fosgate T112D2 subs (3)
Kinetik HC800 battery in stock location (2)
Cascade Power Supply on Board
Audiovox 15” overhead flipdown (2)
Custom aluminum amp covers
NoLimitzBuilt is offline
Old 04-15-2008, 11:03 PM
Utah Scions
xseveredveganx's Avatar
2 Orion H2 12.2's on a Sundown SAZ-3000D at a 2ohm load. Still need to do a little bit of work...
xseveredveganx is offline
Old 04-16-2008, 04:42 PM
D_Unit's Avatar
If any of you are located anywhere near San Jose, CA. and need a competent, ****, obsessive-compulsive perfectionist to meet your car audio needs, Bing is your guy. If you're still looking for another **** obsessive compulsive for something else, then you might want to try Craigslist in the personals section. But seriously, I simply told him that I have a $2K budget that I saved from canceling the stock navigational unit option, and he said no problem.
Why spend 2 grand on just the stock navi when you can get ALL this for a similar price?
Pioneer AVIC D3 + Ipod Adapter + Steering Wheel Controls
Image Dynamics 6.5" Components
Image Dynamics ID12v3
Simplicity Sound Custom Installation
Goals:
1. Decent SQ on a budget
2. Full stealth while retaining all storage bins in the back.
Upfront, the signal starts with a Pioneer Avic-D3 Navi Headunit. Front stage is a pair of Image Dynamics Chameleon 6.5" component set with the tweeters sunk into the A pillars.
Here's a closer look at the driver side tweet...
The Chameleon mid basses were mounted in the stock location and as usual, the entire door is dampened with Edead v4 and ue...
To save me some $$$, we agreed to leave the rear speakers stock running off the D3. After auditioning to the car, I have absolutely no regrets with that decision.
As for the trunk, this is what it looks like when you open the hatch. As you can see, 100 percent completely bone stock looking...
Even when you remove the carpet, it looks like this--STILL looks like stock!
Lift up the stock floor cover, and here is the system. Fake floor in CF vinyl, a single ID12v3 sits in a 1 cubic foot sealed enclosure, while a DLS performance CA51 5 channel runs the entire show, framed by a cut out. The amp is running the front stage active, sending 65-75 watts to each mid and tweet, and around 250 watts to the sub
It's so simple, it's genius...
D_Unit is offline
Old 04-25-2008, 07:44 PM
xsintrk's Avatar
D-unit, I like the material used to cover your enclosure.
Here is my take on the stealth install.
The sub is in a seperate box, the amps are mounted on an angled rack, and then the cover is attached via cap bolts. The amps are under a 1/4" glass window.
Factory Nav
eD 13Kv2
eD 6000s.v2
eD Nine.2
Alpine M500
RF 3Sixty.2
xsintrk is offline
Old 05-12-2008, 03:33 AM
Dirtyred's Avatar
sony mexr5, sony 6.5" scree, 2 cadence 6.5" components, 4 cadence 4" 2-ways, 2 jl 6wO's, 4 jl 8w7's, jl 1000/1v2, 300/4v2, 300/4, 20 farad tsunami cap, 2 yellowtop optimas. i need to make a different amp cover and finish installing the screen but its a decent start.
Dirtyred is offline
Old 05-24-2008, 10:21 PM
Whispaz's Avatar
AVIC-D3
(2) Kicker CVR122
Kicker ZX750.1
4g Monster Cable
7" LCD
5 farad Tsunami Capacitor
Whispaz is offline
Old 05-27-2008, 02:57 AM
Utah Scions
I finally built a false floor. I need to rebuild it and cover it. This is my first false floor I've built and I did learn quite a bit.
And my amp rack.
I reeeeeeally need to invest in a digicam.
Old 05-27-2008, 03:33 AM
lvbitwiz's Avatar
Nothing spectacular
SNS w/Navone LOC
Dice HD reciever
polk db6501
polk 650S
Soundstream pws-10
Kicker zx700.5
crapload of edead and dynamat
martinis by Tanqueray
lvbitwiz is offline
Old 05-27-2008, 07:06 AM
JMS5000's Avatar
Default Stealth install
Here's my setup:
One RocktheBeef designed sub box, .26 cf or so...
One Pioneer 8" slim sub, 120w RMS...
and one Pioneer GM-3300T 2 channel amp bridged to a single 150w RMS...
You can't see any of this unless you move the seats all the way forward. It's a very SQ oriented system. All the components complement each other and sounds very clean and sharp. I love how Scion has made the car so user-friendly, from the ease of wiring (pop out panels everywhere) to special features to accommodate add-ons (like the firewall pass-through nipple and the little bracket on top of the battery that's perfect to mount a fuse holder to).
JMS5000 is offline
Old 05-27-2008, 04:31 PM
xbean's Avatar
Originally Posted by lvbitwiz
Nothing spectacular
SNS w/Navone LOC
Dice HD reciever
polk db6501
polk 650S
Soundstream pws-10
Kicker zx700.5
Beautiful...
It's cool to see some Sin incorperated into your ride.
xbean is offline
Old 05-28-2008, 02:24 AM
xFistsClenchedx's Avatar
Doesn't the sub cause a lot of rattling in the spare tire location? If I was to get a JL Audio 8w7, where would be a good, relatively stealthy location? I've read that the 8w7 subwoofer provides about the same bass as a good 12" sub.
xFistsClenchedx is offline
Old 06-08-2008, 04:16 PM
lvbitwiz's Avatar
Changed the layout a bit, needed more room for the roulette and craps tables
lvbitwiz is offline
Old 06-08-2008, 04:55 PM
Zsanz's Avatar
holy ____ 4 w7s.
heres my fiberglass 2 12" L7s bridged,2 4" ports
2 memphis d1000s
Zsanz is offline
Old 06-08-2008, 06:32 PM
lvbitwiz's Avatar
Originally Posted by Zsanz
holy poop 4 w7s.
2 memphis d1000s
nice glass work
lvbitwiz is offline
Old 07-16-2008, 06:33 PM
Whispaz's Avatar
i finished my newest trunk enclosure. i changed the old purple suede for one that matches a little better, made an in-ground box for 2 subs with star cut-outs looking in that light up blue, opened the middle space up to change the old 7" screen to a 19", and have Rock Band for the Wii!
Whispaz is offline
Old 07-16-2008, 07:33 PM
Zsanz's Avatar
and now ur selling them?
Zsanz is offline
Old 07-16-2008, 07:54 PM
Whispaz's Avatar
nah, not any more. everytime i try to change my sig it signs me off
Whispaz is offline
Old 09-21-2008, 03:34 PM
FrankH's Avatar
0 gauge monster cable split to 2 4gauge
Alpine IDA X001 head unit.. so I wont ever have a clutter of CD's in my car!
Alpine f600
Alpine M1005
Apline type R components 6.5"
Apline type R coaxle 5.25
Alpine type X 12"
Tsunami 1farad cap
Optima yellowtop (coming very soon)
simple yet effective
FrankH is offline
Quick Reply: Car Audio Setup Pics required
