illuminated door sill enhancements no longer on
Old 06-29-2010, 07:30 AM
miketag's Avatar
Default illuminated door sill enhancements no longer on
Hi I have a 08 Scion XB and the illuminated door sill enhancements no longer work. I was wondering if I could replace the battery or something because I liked them
miketag is offline
Old 06-29-2010, 01:55 PM
Scionetics
RevolutionAutomotive's Avatar
They should have been hard wired. Check your fuses and make sure none are blown. If thats not the case, maybe a wire got pulled.. look around under your dash for anything out of place.
RevolutionAutomotive is offline
Old 06-29-2010, 10:30 PM
TrevorS's Avatar
As said above, they're hardwired to the car. I gather somebody else installed them for you, so if you want to checkout the wiring, review the Illuminated Sill accessory PDF in the xB2 tech files.
TrevorS is offline
Old 06-30-2010, 04:22 PM
Big_Jim's Avatar
How old is the car, and did you have the dealer install them? Take it back to the dealer (in under 36k on door sills) and see if they'll check them out.
Big_Jim is offline
Old 07-09-2010, 09:49 AM
Gutling's Avatar
They are hardwired, and if under warranty def take it by and let the dealership check it out. The wires run under the trim plastic and T tap into the factory harness. One of them could have come loose.
Gutling is offline
wejarrell
10
08-05-2015 09:19 PM
x2x3
08-04-2015 09:07 AM
Subaru86
07-28-2015 03:05 PM
umnitza
07-25-2015 07:54 PM
Quick Reply: illuminated door sill enhancements no longer on
