Scion xD ICE & Interior In-car entertainment and electronics...
Installed new head unit, clock doesn't work.
Old 03-08-2015, 05:00 AM
sehall6h's Avatar
Default Installed new head unit, clock doesn't work.
09 xD
Ok so I installed a new double din unit and it has no spot to plug the clock to. Here's the kicker, the head units clock doesn't work correctly. So I would really like my stock clock to work buy have no idea how to hook it up properly to the unit. Oh and also my airbag light has been on since the install. Any suggestions? Sorry I'm kind of new at this.
sehall6h is offline
Old 02-07-2016, 04:29 AM
Bobakiss's Avatar
Originally Posted by sehall6h
09 xD
The clock and hazard switch should have its own wires and harness. Look and see if the cable is loose in the dash or even accidentally plugged into the head unit. I've done this before, accidentally plugging the clock cables into my radio and blew the fuse. I was surprised to find that the factory stereo has a socket on the back that nothing plugs into and has the shape of the clock harness so it's really easy to mix up.
Bobakiss is offline
Old 02-21-2016, 04:28 PM
Topher709's Avatar
You probably didn't plug in the harness to the clock. Remove the center dash trim- if there is nothing attached to it, plug in the harness. This will allow you to use your hazards again and your air-bag light will turn off. What head unit do you have- I find it suspicious that it cant keep it's own time... I can post pictures if you need it...
Topher709 is offline
clickclickw00t
02-18-2015 08:57 PM
NewBox06
02-03-2015 04:02 AM
wiltonhall
01-28-2015 03:46 PM
billzor
Scion tC 2G ICE & Interior
01-17-2015 12:38 PM
lunchbx05
12-11-2014 06:13 PM
Quick Reply: Installed new head unit, clock doesn't work.
