Scion tC 2G ICE & Interior In-car entertainment and electronics...
How to Remove Steering Wheel Plastic (with pix)..
Old 09-05-2012, 02:07 PM
  #61
StatuSCheckA's Avatar
Those look nice.
I dont plan on doing an interior paint scheme, but does any one have pics of the steering wheel pieces in matte, or gloss black?
StatuSCheckA is offline
Old 09-28-2012, 07:36 PM
  #62
Uncle_L's Avatar
Originally Posted by Zeus_tC
This looks good. I may want to wrap mine with 3M DiNoc Carbon Fiber vinyl though.
Good choice!!!
Uncle_L is offline
Old 09-28-2012, 10:55 PM
  #63
Takanon423's Avatar
I tried.
Takanon423 is offline
Old 10-02-2012, 06:19 PM
  #64
devanb3's Avatar
I think it will look goo I the car but damn the hair net looks horrible
devanb3 is offline
Old 11-06-2013, 05:35 AM
  #65
tc2newb's Avatar
Any update pics on the CF steering wheel?
or any1 else with CF vinyl wrap?
_________
tc2newb is offline
  #66
tc2newb's Avatar
considering this
tc2newb is offline
Old 06-13-2022, 07:39 PM
  #67
Whistler's Avatar
Default Anything else?
Originally Posted by devanb3
First off I'd like to thanks Superpickel for the original how to on this before anyone starts this it must be noted that I am or Superpickel is not responsible for any damages or the airbag being deployed.
With that said first things first remove you need to disconnect the negative battery cable. this will require a 10mm wrench This will disengage the steering wheel airbag.
Attachment 51192
Next, remove two black square plates, from the steering column, on both sides of the steering wheel. This allows you to see behind the steering wheel itself.
Attachment 51193
Attachment 51194
After that, you will see two rods, running up and down, one on each side. These rods are spring action and set into a notch on a rod protruding beneath the horn cover to allow the cover to be pushed in (to honk the horn) and release.
Using a screw driver, push the straight up and down rods inward. This will release the horn cover and the air bag. Feel free to unplug the clip for the air bag (please see note at bottom)
Attachment 51195
Attachment 51196
After that is out, you will see three pieces. Those coveted three pieces that you have been staring at for the past 3 weeks that are still silver while everything else has been primed, painted, and cleared to perfection.
Holding these three pieces are a few Phillips head screws. there are 2 screws in the front of the steering wheel
Attachment 51197
Now the difficult screw is located behind the black plastic behind the wheel itself. To remove this the easiest way I found is to put the steering wheel upside down and lower the wheel all the way down force the black plastic down and proceed to remove the screw.
Attachment 51198
Take them out, have your way with painting and then replace the pieces.
If you're like me and cant wait the recommended dry time for the paint and not go anywhere you can replace the horn and negative battery cable
Attachment 51199
Note: I did not unclip the connector for the air bag. Reason being, and I'm not sure of the validity of this, is because I have heard of air bags not deploying later on after reassembly (later down the road in wrecks)
because they had been tampered with (unplugged before). This is the reason I left mine plugged up. But like I said, not 100% sure. Better safe than sorry.
_________
Thnx for the assist in removing my plate and airbag....can you help with fixing the horn ? Mine is the 2012 Scion TC like in your vid but not sure which is the horn switch to fix?
Whistler is offline
CombatmedicR56
11-12-2020 01:53 AM
fur_pig
03-20-2020 04:28 PM
evolving_machine
01-13-2015 08:04 PM
FurionAlpha
Scion tC 1G ICE & Interior
01-12-2015 08:25 PM
Beesh
01-09-2015 06:30 PM
Quick Reply: How to Remove Steering Wheel Plastic (with pix)..
