Oil Quality- Jiffy Lube
Old 05-26-2007, 08:17 PM
  #41
paul34's Avatar
You just used "quality" and "Jiffy Lube" in the same sentence
What kind of oil do they use? No oil, because they usually don't even do what you pay for anyway
Honestly, I'm not even exaggerating. Talk to people who once worked for JL and had the wisdom to get the hell out. They can tell you plenty of horror stories...
paul34 is offline
Old 05-31-2007, 04:38 AM
  #42
midgie's Avatar
Jiffy lube sux IMO. I took my TC there for the 3rd oil change, (needed it in a rush and couldn't wait for Toyota to do it) and as I roll up the grease monkey comes out and asks what oil I want to put in it. I told him 10w30 and he looks at me and says "you want to put REGULAR oil in THAT???" I asked him what he recommended and he said full synthetic and that was the only kind he would put in there. I told him I would go somewhere else if he didn't put in 10w30 and he told me he wouldn't be responsible for any warranty issues for using the wrong oil.
midgie is offline
Old 05-31-2007, 10:29 PM
  #43
paul34's Avatar
Shouldn't you be using 5w30?
And chances are, he just dropped some 10w30... or 20w30... those guys don't really look.
Heck, its commonplace in Jiffy Lube to pump out your existing oil, run it through some machine, then pump it back into the engine.
paul34 is offline
Old 05-31-2007, 11:28 PM
  #44
midgie's Avatar
The manual showed 10w30 as being ok so that's what I assume should go in it. My point in my previous post was that the JL guy wanted to upsale me to synthetic and then tried to scare me about using anything other than synthetic. Obvs he didn't know crap about scions.
midgie is offline
Old 06-01-2007, 01:37 AM
  #45
paul34's Avatar
Gotcha. Chances are he would've said that to anyone with a new-ish car.
I'm also pretty sure he tried to trick you solely because you are a female.
paul34 is offline
Old 07-01-2007, 11:45 PM
  #46
George's Avatar
Originally Posted by jmiller20874
Originally Posted by BOXED N
...I use to put tranny oil in my motor to flush it prior to every other oil change in my GSX. Just add 1qt with the old oil, run it for a couple minutes & then change it. My oil always had that nice golden color.
I'm not so sure that this is something that I'd want to try. I'd just assume take it the have it power flushed every 20,000 miles or so. Scott, your thoughts?
"Power flush" is a ripoff. For that matter, anything that purports to clean deposits from your oil is a ripoff. For argument's sake, let's say that there are grunge-filled deposits clinging to the inside of your engines. If you do nothing, what will happen? They'll stay right where they are! Let's say you flush them loose somehow. In that case they will start to circulate with the oil. If they go through the pump they'll be caught in the filter. If they are already downstream of the filter, the grunge you broke loose goes right through your bearings, the last place you want them to be! Bad News!
Change your oil regularly and you won't have any buildup problems.
George is offline
Old 10-12-2007, 03:29 PM
  #47
yanges's Avatar
the only things that really need occasional flushing are the transmission and radiator/cooling system...
yanges is offline
Old 10-19-2007, 09:05 AM
  #48
enzochan's Avatar
Do it yourseld man and get to know your ride.
enzochan is offline
yupinmytC
21
11-08-2019 09:34 AM
mudguy
10-22-2015 04:31 PM
crimson_sinn
09-25-2015 09:41 PM
Klashan
09-24-2015 12:39 PM
vi3tb0i09
09-23-2015 08:32 PM
Quick Reply: Oil Quality- Jiffy Lube
