Brake Pad Change (No Pics)
Old 06-08-2006, 08:38 PM
kanundrum's Avatar
anyone got any instructions on how to replace brake lines. Ill be getting a a stop tech kit soon.
kanundrum is offline
Old 06-15-2006, 02:46 AM
roflitzjinno's Avatar
definately wouldve been helpful with pictures.
roflitzjinno is offline
Old 06-16-2006, 04:42 AM
Sam_J84's Avatar
interesting... pictures would help though.
Sam_J84 is offline
Old 06-16-2006, 04:50 AM
Spect2K3's Avatar
^^^ agreed, but its still an awesome thread nevertheless
Spect2K3 is offline
Old 06-26-2006, 06:04 PM
djjason101's Avatar
Default Brakes
Do you change all four brakes at a time? Or do you just do the front?
Thanks!
djjason101 is offline
Old 06-26-2006, 10:55 PM
Mmartin_47's Avatar
Usually the front is done... 30% of braking power is applied to the rear.. but eventually later you will have to change the rear pads as well.
Mmartin_47 is offline
Old 06-27-2006, 04:17 AM
xnevergiveinx's Avatar
what about the pads in the rear for the parking brake?
xnevergiveinx is offline
Old 06-27-2006, 06:08 AM
Mmartin_47's Avatar
those are in the rear...
Old 06-27-2006, 03:16 PM
yeah i know, our rear rotors have built in drums from the parking brake, the parking brake has pads. has anyone changed them?
Old 06-27-2006, 04:41 PM
Mmartin_47's Avatar
Hmm not yet for me. I have 25,000 and there still good. I changed the front however.
Old 06-27-2006, 06:35 PM
lapulapu's Avatar
I've asked Autozone and Pepboys for 06 Tc pads but they dont have them in stock or have a part number. Do you guys think I can use 05 pads?
lapulapu is offline
Old 06-27-2006, 07:10 PM
djjason101's Avatar
Default Brake Pads
i ordered oem from McGeorge's and got a great deal...
Old 06-27-2006, 07:14 PM
lapulapu's Avatar
just googled for McGeorge's Toyota and they're located in Virginia. YIKES!
lapulapu is offline
Old 06-27-2006, 10:22 PM
djjason101's Avatar
Default Break Pads..
But they ship...
Old 06-27-2006, 11:50 PM
mcgeorparts.com is a quality site you should get them in less than a week. even if youre in cali.
Old 07-02-2006, 04:04 PM
jwaggz82's Avatar
would anybody consider putting pictures to the instructions just so we can bring the comp right out to car while performing the pad swap? .... i know what someone is going to say .... "how much clearer can it get" ... well - for someone (like myself) that has never bothered changing the pads and has always taken it to a shop .... seeing the pictures before I go out side and knowing 100% what everything looks like .... It would help. I think that some other guys/girls might feel the same way. I know I can follow directions and do exactly what it says (and eveybody says its easy to do) but it does help knowing what things look like even before hand.
jwaggz82 is offline
Old 07-02-2006, 04:42 PM
chubster41's Avatar
ok well Im going to be changin my brakes not breaks soon
so i will try to take detailed pics....
chubster41 is offline
Old 07-02-2006, 04:47 PM
jwaggz82's Avatar
yes but doesnt mcgeorge only have the stock ones? there might be a better choice then the stockers.
jwaggz82 is offline
Old 07-02-2006, 04:51 PM
chubster41's Avatar
order from here
https://www.scionlife.com/forums/vie...123058&start=0
good guys
Old 07-04-2006, 07:28 PM
chubster41's Avatar
ok well I was planning to change my brakes but when I took the old ones out they were fine.....plenty of brakes left but these are some of the pics I took which would be the process in changing them
front brakes
after taking the wheels off
step 1: locate the top bolt and use a 14mm socket and pry it loose
http://i2.photobucket.com/albums/y42...0/100_1708.jpg
http://i2.photobucket.com/albums/y42...0/100_1707.jpg
step 2: swing the caliper down and the brake pad will be exposed
http://i2.photobucket.com/albums/y42...0/100_1709.jpg
step 3: note the way u take the brake pad out which will be the same way u put the new one on..also note the metal brackets as im sure u will use those again (im not sure since I didnt change mine)
http://i2.photobucket.com/albums/y42...0/100_1710.jpg
http://i2.photobucket.com/albums/y42...0/100_1711.jpg
thats as far as I got but when u do change them u will need a c-clamp to compress the piston so the caliper goes over the new brake pad then just bolt it up again using the 14mm socket
after all this is u will need to bleed ur brake as well as add ur brake fluid.
Im not sure if I covered everything as im in a rush to get out and to swimming...lol
but if I did forget anything let me know so I can edit this...
also this is to be used as a guide so i will not be responsible for any damaged caused...
gracias....
Quick Reply: Brake Pad Change (No Pics)
