gas mileage and wheels/tires
Old 03-11-2014, 06:17 AM
scionxb1stgen's Avatar
Default gas mileage and wheels/tires
What size rims and type/size tires will give the best gas mileage for a 1st gen xb?
scionxb1stgen is offline
Old 03-11-2014, 06:35 PM
johnp's Avatar
I would also suggest getting something lighter which would also help with less rotational force and better gas mileage.
johnp is offline
Old 03-12-2014, 04:30 AM
Default Tire/Rim Better gas Mileage?
When you suggested something lighter ,do you mean a lighter rim,like aluminum or an alloy/or are there lighter tires as well? Also I'm still wondering if height makes a difference?I believe I was told.,as an example, that a 14'' rim would get better mileage than a 15'' rim?
Old 07-10-2014, 04:05 PM
wzard999's Avatar
Default less is more
Lightest wheel, lightest tire, lowest friction tire (hardest tire). Research the factory equipment for the Prius; it may bolt up to the xA/xB/Yaris/Echo. I also suggest seeking out the customer service reps at tirerack or discounttire for information. They know their stuff.
Oh, and 15-inch Konig Heliums are only about 11-pounds a pop. They're also relatively inexpensive.
I'm not sure if ride height makes much of a difference. I suppose that, in theory, the lower the ride height, the less wind resistance will reach the undercarriage. But. . . the wind resistance is going to infiltrate the undercarriage regardless of height. What would really help reduce wind resistance underneath is some smo-o-o-o-othness, like the undercarriages of late model super cars, exotics and hyper-milers. Now, concerning wheel/tire height - the lower you go in comparison to factory spec, the more and faster your odometer is going to spin = the more mileage you will see but not truthfully travel = the more fuel economy you will measure but not truthfully achieve.
wzard999 is offline
yupinmytC
21
11-08-2019 09:34 AM
BlingSlade
11-20-2015 06:56 PM
mudguy
10-22-2015 04:31 PM
prescottn
09-22-2015 01:30 PM
BlingSlade
09-05-2015 08:52 AM
Quick Reply: gas mileage and wheels/tires
