Small Questions Thread (Use this instead of creating new threads)
Old 11-27-2013, 06:25 PM
  #641
itzallgood707's Avatar
I believe the auto is larger due to the the fact that the auto weighs more than the manual. I could be wrong but it makes sense.
Seeing as how the TRD is the is the same size as the Progress ill probably just end up getting the TRD due to it being much cheaper than Progress (yes I know the come with new endlinks).
Sent from my SAMSUNG-SGH-T989 using Tapatalk
itzallgood707 is offline
Old 11-29-2013, 10:57 PM
  #642
jcaudill's Avatar
Recommended Mods for an 06 Tc?
jcaudill is offline
Old 01-16-2014, 07:51 PM
  #643
DaTRican's Avatar
Driverside window issue
When I roll my window all the way up with the auto up feature it always triggers the safety sensor and makes it roll down about a half inch. Is there any to fix that?
DaTRican is offline
Old 01-16-2014, 08:01 PM
  #644
Tak16's Avatar
Reinitialize the wind
Tak16 is offline
Old 01-16-2014, 08:03 PM
  #645
Tak16's Avatar
Sorry. Accidentally hit send on my phone. Reinitailize the windows. The procedure should be in the manual on how to do it. If you unplug the battery, you'll have to reinitialize the sunroof as well.
Tak16 is offline
  #646
DaTRican's Avatar
Explain please
DaTRican is offline
Old 01-16-2014, 08:07 PM
  #647
DaTRican's Avatar
Thank you I'll check it out
DaTRican is offline
Old 01-20-2014, 04:32 AM
  #648
Not_Snow's Avatar
If I get a Skunk2 exhaust system, knowing it's from the S-pipe back, will I have any problems with emissions testing?
Not_Snow is offline
Old 01-21-2014, 07:17 PM
  #649
that_G_U_Ys_tC's Avatar
No........not that I'm aware of
that_G_U_Ys_tC is offline
Old 02-21-2014, 08:40 PM
  #650
mattchuetc's Avatar
Default tc catalytic converter
I have a CEL for the cat because there is not one what can I do to fix it and or what aftermarket cat can I use to fix it because I have a header on it
mattchuetc is offline
Old 02-21-2014, 11:50 PM
  #651
Vladislav's Avatar
You need a anti fouler to screw into the s-pipe and then screw the o2 sensor into that. Here's a thread that can help. https://www.scionlife.com/forums/showthread.php?t=22180&styleid=14
Vladislav is offline
Old 04-19-2014, 03:05 AM
  #652
wicked_tc187's Avatar
Default weird sound
Hi guys i have a question I've been having problems with my scion its making a weird noise inside the cabin in the passenger side
there's the video thanks in advance
wicked_tc187 is offline
Old 04-19-2014, 06:27 AM
  #653
tc913's Avatar
does this happen when the fan is on? cause the only thing that is in the glove compartment is the blower and the evaporator for the ac. see if you can hear the sound outside of the car but it is def coming from the engine compartment.
tc913 is offline
Old 04-19-2014, 03:52 PM
  #654
Yeah I even took out the glove box and I couldn't hear anything from there it comes from the engine compartment but you can only really hear it from the inside you know
Old 04-19-2014, 04:02 PM
  #655
And it happens when the fan or ac is off or on
Old 04-27-2014, 12:18 AM
  #656
dstufli's Avatar
Maintenance at 130k
I've replaced tires, front brake pads, and sparks plugs.
I'm assuming shocks and struts? Price? DIY is not an option (no space, or time).
Anything else that I need?
And yes, I'm lazy and suck at search. The DIY video on the struts was cool, but it's not going to happen.
Thanks!
-d
dstufli is offline
Old 05-01-2014, 02:10 AM
  #657
Taintstick's Avatar
Originally Posted by dstufli
Maintenance at 130k
Thanks!
-d
Just because the car has 130k doesnt mean it needs struts or springs. IF they are blown then yes you need them but there is no set milage when the struts and springs will go bad...
As far as anything else you need, personally i would replace ALL fluids but without knowing the maintenace history of the car it may not be necessary. I would also throw on a serpentine belt.
Taintstick is offline
Old 05-05-2014, 03:35 PM
  #658
Cisco_TeamShogun's Avatar
Guys:
Is yellowxhoodie (Cory) still around?
I need some decals done that he previously did for me (thus why I cant just go anywhere and re-buy them)
LMK.
I am looking for him.
Cisco_TeamShogun is offline
Old 05-09-2014, 07:10 PM
  #659
Taintstick's Avatar
Originally Posted by Cisco_TeamShogun
Guys:
LMK.
He comes around from time to time, i saw a sticker sale like a month or 2 ago. I think he checks his account somewhat regularly...did you try a PM?
Old 05-12-2014, 03:14 AM
  #660
yeah...
I was able to get him thru email, responded once,
I need old decals replicated, he had the templates, so if anyone know anyone that does decals, that can replicate other's designs LMK.
Quick Reply: Small Questions Thread (Use this instead of creating new threads)
