Changing stock interior map lights to LED
Old Jun 23, 2007 | 06:58 PM
matic's Avatar
Default Changing stock interior map lights to LED
I'm interested in changing the stock interior map lights to some bright (hyper) white LED lights. Can anyone help me identify what the appropriate type of replacement lights would be and/or recommend a reputable supplier for these lights? I've included pics and specs of the stock bulbs below.
Toshiba
12V8W B73
Size (approx): 28mm or 1.125"
Old Jun 25, 2007 | 01:47 AM
LEDmod's Avatar
They are size 194
There are many different type of LED bulb you find from dim to crazy bright....
Old Jun 25, 2007 | 06:47 AM
mikemann's Avatar
can you get the square led arrays in there? How do you seperate the lens from the housing? Also was this just a yank down from the ceiling? I don't have my xb yet, but there have been previous posts about how this was hard to get down?
Old Jun 25, 2007 | 07:02 AM
SquallLHeart's Avatar
yank, twist, remove the bulb, replace.
the universal led arrays you speak of should come with different adapters. i'm sure there are ways to make it fit.
Old Jun 25, 2007 | 07:06 AM
mikemann's Avatar
What I meant was I assumed the clear frosted lense came apart to do the bulb change. Maybe I don't have a feeling for the size of the LED arrays, but I thought they would be bigger than that round twist lock housing for these bulbs, was trying to figure out how you get the LED array in there. :-)
Old Jun 26, 2007 | 07:07 AM
matic's Avatar
The easiest way to get the dome light unit out is to use a thin flat screwdriver (or similar) and push the two metal clasps at the top or bottom of my first picture. The whole unit should come out pretty easily after this.
Old Jul 12, 2007 | 12:17 AM
michaelbailey10's Avatar
superbrightleds.com
Old Jul 12, 2007 | 02:38 AM
fairladyz541's Avatar
Team Sushi
Dose anyone know where I can get Super Bright LEDs to replace the rear plate OEM ones. I noticed on the new Lexus that they are bright compared to ours..................
Any ideas
Old Jul 12, 2007 | 06:18 AM
toyotaisme's Avatar
be nice to change them in blue.
Old Aug 4, 2007 | 05:05 PM
k1tz1e's Avatar
Is the dome light bulb a 194 also or are they different entirely?
Old Aug 10, 2007 | 08:03 PM
ray_18's Avatar
the dome is 28mm but the closest one i found was 30mm just push it in there superbrightleds.com is the place
3022-x4 LED Festoon bulb
30x10mm (1.181 inches long)12 VDC Festoon Base Bulb with 4 LEDS
Select LED Color
$ 1.89
Old Aug 10, 2007 | 08:06 PM
ray_18's Avatar
Superbrightleds.com 12v car bulb then scroll all the way down continue 2 car bulb then festoon then the second festoon base buy now then first one on second page
Select LED Color
$ 1.89
Thats for the dome light
Old Aug 11, 2007 | 04:23 AM
mikemann's Avatar
Just an update for those checking this out. You can change these bulbs easier by just popping out the clear covers that you push in and out instead of pulling out the whole housing.
The map lights are 194's and the dome light is a 31mm festoon.
The rear trunk light is a 28mm and good luck finding those. You can bend the tabs back and fit a 30/31mm one in there and it will work fine.
I purchased a 25-LED array for the map lights, these are awesome...super bright. I bought white and decided to go with blue, so I ordered a second set. If anyone wants a set of these for their xb - I have an extra set. PM me.
Old Aug 11, 2007 | 08:30 AM
medullaman's Avatar
I got one of these to put in my ome light, but it was to big to fit in the dome. after reading this I decided to go try it myself. It worked great and looks sweet. I can't wait to get the other one installed now. Now I just need to ind a solution that fits in the dome.
Old Aug 18, 2007 | 04:51 AM
lvbitwiz's Avatar
These were added today, all came from superbrightleds.com
http://i108.photobucket.com/albums/n...iz/rearled.jpg
http://i108.photobucket.com/albums/n...ledblinker.jpg
http://i108.photobucket.com/albums/n...z/newlight.jpg
http://i108.photobucket.com/albums/n...bluelights.jpg
I also changed out the plate lights with the 6 led 194's in white. I just need to take a pic
Old Aug 24, 2007 | 05:19 AM
STEVEN107's Avatar
does anyone know how the wiring works for the interior lights? i just switched all interior lights to led and it was super bright and now it won't turn on unless all doors are locked (by switch) and its super dim. any ideas?
Old Oct 23, 2007 | 09:50 PM
DJ_FroZone's Avatar
so how do u get the plate lights out? or how do u change them?
Old Oct 23, 2007 | 11:30 PM
DJ_FroZone's Avatar
edited i got the doms and maps out but how do u get the trunk and plates out
Old Oct 24, 2007 | 06:21 PM
DJ_FroZone's Avatar
edit again i got it! the plate lights are way freakin hard to get too. but i still did it got the trunk lights too
Old May 21, 2008 | 01:02 PM
broken_20_2's Avatar
Sorry for bringing this up again, but I am LED impaired. I bought some super white LED's (194, 5 bulb) for my map lights. They work fine. However, I want to change to blues, and I would like them a bit brighter. I also want to change my dome light to blue as well. Now, my questions:
1. What is the biggest LED array that will fit in the map lights? Can I go with a 10 led array in a 194, or will that be to big? Is there an alternative to a 194 bulb that I should be using (without having to hard wire, since I'm an idiot when it comes to electrical)?
2. I see that some of you have used a 30mm festoon bulb for your dome, and some have gone with a 25 LED array. I would like to do the 25 LED array since it would be brighter. Can you provide me with a link to exactly what I want to buy?
LED's are new to me, and I don't want to waste money on something that isn't going to fit or I'm not going to be able to install (i.e. having to hard wire). I REALLY appreciate the help!
