Tire Pressure Sensor Recalibration
Old Oct 4, 2004 | 11:01 PM
mikochu's Avatar
Default Tire Pressure Sensor Recalibration
Contributed by BlueBox.
Use this procedure to recalibrate aftermarket wheels/tires on the tC:
1) Turn ur engine on
2) Set the E-Brake (pull up)
3) Press and hold the tire "reset" button in the glove box
a) The tire pressure sensor light should blink 3 times consecutively
4) You must drive the vehicle for about 10 miles without turning off the engine. This will recalibrate the tire pressure sensor.
Old Oct 30, 2004 | 03:47 PM
xAlex's Avatar
is there anything like that for the xA?
Old Oct 30, 2004 | 06:04 PM
mikochu's Avatar
Nope... Just get one of those nifty tire gauges with the bleed valve and check your tire pressure every month or so...
Old Nov 2, 2004 | 04:55 AM
stillkicking47's Avatar
What is this for?
Old Nov 3, 2004 | 05:11 PM
SuperCrunchyAction's Avatar
Originally Posted by stillkicking47
What is this for?
"Use this procedure to recalibrate aftermarket wheels/tires on the tC: "
Old Dec 15, 2004 | 04:23 PM
05idinktc's Avatar
it goes the same for the stock wheels right?
Old Mar 5, 2005 | 04:55 AM
TurboMe's Avatar
wheres the tire pressure gauge? :D
Old Jul 24, 2005 | 01:51 AM
yesti's Avatar
been thinking about this and does anyone know the threshold for the tire pressure warning to trigger +/-psi? and is it part of the abs system meaning would the abs come on sooner or later depending on what the pressure was 'set' to versus what it actually is? like if you pump the tires up to 51psi cold, set the system then bleed them out to 40 would that affect abs activation in any way? i'd try it but my commute to work is only ~8 miles (and takes 30-45 min!) crawling on the freeway.
Old May 21, 2008 | 12:02 AM
jsingh's Avatar
OhioScions
what is recalibration?
Old May 21, 2008 | 01:13 AM
Sciond's Avatar
hmm why is this here still holy old threads
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
GoodVibes
Mar 3, 2015 09:47 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
