Please help soon( brake fluid)
Old Jul 23, 2007 | 06:28 PM
BlangKang's Avatar
Default Please help soon( brake fluid)
Hey guys i just need to how much brake fluid I need go get to change over to dot 5? I am placing my order soon and Im at work LOL.any help would be great[/list]
Old Jul 23, 2007 | 06:38 PM
BlangKang's Avatar
sorry dot 4 motula
Old Jul 23, 2007 | 08:53 PM
low_down_xb's Avatar
for what reason are you changing to dot 4
Old Jul 23, 2007 | 11:19 PM
aye87's Avatar
doesnt the owner manual say how much fluid it holds?
Old Jul 24, 2007 | 03:17 PM
JSosa's Avatar
With 2 bottles you should be fine. If your going to entirely bleed the system 2 is enough. BTW, why are you changing your brake fluid?? Unless its really old or your going racing, why change ALL the fluid??
Old Jul 24, 2007 | 07:24 PM
BlangKang's Avatar
thanks for the reply, I am planning on Autocrossing the XB and trying to get the most out of the brake without going to a big brake kit. Also big props to buybrakes.com put my order in yesterday and just got it now. Way great service and that shipping was freee
Old Jul 24, 2007 | 07:28 PM
BlangKang's Avatar
also going to all braided SS lines, so might as well do it all at once
Old Jul 24, 2007 | 07:50 PM
you wont notice any difference with dot4
Old Jul 24, 2007 | 10:11 PM
streetlethalxb's Avatar
motul doesnt brake down, under extended high temps, like
OE fluid does (turns brown, with that green slime in the
strainer). Thats the difference the fluid he is going to switch
to makes, which in the long run affects brake system hoses
and seals. For an autcrosser, fluid, SS brake lines and pad
upgrades are standard.. your doin the right thing
Old Jul 25, 2007 | 12:34 AM
BlangKang's Avatar
Thanks for the insight, thats my been plans and thoughts from the start. I don't think these upgrades will equal a BBK upgrade but much much better then stock. I will give my feed back from my upgrade so others maybe looking to do the same or just wanting something better then stock
Old Jul 25, 2007 | 03:19 PM
JSosa's Avatar
I have SS lines, fluid and pads. The braking power is virtually tripled with these simple and cheap modifications. I would recommend the following:
1.) SS lines from Agency Power or Footwork
2.) Brake Fluid use Motul RBF 600
3.) Pads: Hawk HPS or EBC Green
The Hawk HPS and EBC green really increase braking power, but the fade and bite are still present. If your looking for a really aggressive bite for your brakes, then your going to need pads that are slightly more racing, liked EBC Red or Yellow and Hawk Blue's.
Old Jul 25, 2007 | 06:22 PM
BlangKang's Avatar
wow good to hear, soon as my agency ss lines show up I'll start this mid. Then I really need new tires, my stocks look like slicks but with out that whole traction thing LOL
I did go with the axxis ultimate pads so I will see how I like them. Thanks again
Old Jul 26, 2007 | 04:56 PM
JSosa's Avatar
Dont want to make you feel bad or anything, but you should have gone with the pads i recommended, the AXIS pads are a tad better than OEM replacement pads. The only thing i would tell you to watch our for is brake fade, which happens very quickly if your not paying attention.
Old Jul 26, 2007 | 09:46 PM
BlangKang's Avatar
well I did some work and found that the AXXIS pads do really good, so I will give them a shot. Worse comes to worse later down the road i get some better pads. I prob do that when I upgrade to powerslots. ALso got my Agency SS brakelines and I plan to install everything tonight.....wish me luck
Old Jul 27, 2007 | 06:11 AM
BlangKang's Avatar
update, got everything installed, so far so good. Took it around the block and fell 100% better then stock. I can't go have fun beacsue I wanna wear them in. SO when I get my new tires here shortly I will give a better up date.
gqdabien
Oct 8, 2015 05:36 PM
olyellr
Sep 28, 2015 10:32 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
