Need help on Amplifier and Infinity Basslink Install
Old Aug 5, 2007 | 03:02 AM
pinoy_TSX's Avatar
Default Need help on Amplifier and Infinity Basslink Install
Hey guys I just got my Infinity Basslink and Kennwood KAC-7202 2 channel amp to power up my front components. I want to install these with myself to save some $ for the install and of course to learn.
I'm planning on buying these wiring kits:
Stinger HPM SWKH8RS for Kenwood Amplifier
Stinger HPM SWKH10R for Infinity Basslink
Some Questions:
1. What else do I need? Do I need a Fuse Distribution Blocks or Power Distribution Blocks since I have 2 components to power (Basslink and Kenwood Amp)?
2. How will I connect the power cable of my basslink and amplifier into the battery?
3. How about the their ground cables? Can I just bolt both of them on the chassis on my car?
Thanks for your help!
Old Aug 5, 2007 | 03:36 AM
mattieg's Avatar
Yes you will need a fused distribution block in order to supply power for both amps. I would recommend at least a 40 amp fuse for the block. (you will need two) To connect the power to the battery you will need to go through the firewall. If you have an auto it will be really easy because you can drill a whole where the clutch plate is. If you have a standard your going to have to find another place. And yes you will ground the grounds to your chassis but make sure you scrap away the paint before you drill them down.
Old Aug 5, 2007 | 05:50 AM
pinoy_TSX's Avatar
Ok, so do I still need to use the inline fuse that comes with the wiring kits? Just wondering because the Fuse distribution blocks already have fuses.
Will this work for my components?
Stinger Fuse Distribution Block
Thanks!
Old Aug 5, 2007 | 06:46 AM
tCeeJay's Avatar
There are kits that are made for a 2 amp installation:
http://www.sonicelectronix.com/item_...0+BAP1000.html
Old Aug 5, 2007 | 10:07 AM
pinoy_TSX's Avatar
But that one comes only with 1 fuse right? hmmm... I'm a little bit confused now.
Old Aug 5, 2007 | 08:21 PM
pinoy_TSX's Avatar
How about the remote turn on wire? Do I need to connect both remote turn on wire from my Kenwood amp and basslink to my HU?
Old Aug 5, 2007 | 11:45 PM
tCeeJay's Avatar
You only need one fuse if you are going with a 2 amp kit. For the remote turn on wire, you can have one wire coming from the HU and then splice it on the other end.
Old Aug 6, 2007 | 01:11 AM
mattieg's Avatar
You will need one fuse ten inches or less from the battery. Then two more fuses for the distribution block. Its better to have a fused distribution block so nothing goes wrong. Also you can take a separate piece of wire for the remote turn on and run it from one amp to the other.
Old Aug 6, 2007 | 04:08 PM
tCeeJay's Avatar
mattieg is right... I totally forgot about the fuses in the distribution block
Old Aug 7, 2007 | 01:50 AM
mattieg's Avatar
It happens lol. But I think he should be good with something like that. Good luck with everything.
Old Aug 7, 2007 | 07:42 AM
pinoy_TSX's Avatar
On the remote turn on wires, do I need a relay ?
Old Aug 7, 2007 | 02:44 PM
blazeplacid's Avatar
for wiring go to knuconecptz.com BEST price on everything. Ive ordered from then about 4 times and everything is perfect. great quality stuff
Old Aug 7, 2007 | 07:06 PM
mattieg's Avatar
Not you do not need a relay for just those 2 amps... if you did five amps or something outrageous then you would need a relay.
Old Aug 8, 2007 | 05:38 PM
pinoy_TSX's Avatar
Yes I ordered my wiring kits from knuconcepts and I only spent $70.00 for both. Great price IMO.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
