Engine Damper kit , Does it worth buying?
I have found this on eBay. I am a newbie, so can anyone tell me what it is? Does it worth buying? :? Can I install this myself with hand tools?
Thank you
Weapon R Engine Damper kit
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Thank you
Originally Posted by Zombietime
Junk. Go check out a 400 hp mustang cobra and see if it has something like this installed.
Originally Posted by Scott17
What if you don't have wheel hop to begin with?
That bar you posted a link to is for chassis strengthening...something very similar to the JIC under bracing for the box. Most Mustang owners combine something like the k-member brace with a set of subframe connectors and a 3-point strut tower brace. Unfortunately every Mustang until probably the new '05 has the structural rigidity of a wet noodle, so bracing up the chassis in the modern Mustang is numero uno on the list of modifications. It does help get the power to the rear wheels, but most importantly it keeps the chassis from flexing and eventually deforming as time goes on.
This mod mentioned above...hmmmm. I've seen simlar things used in very high HP cars where the stock motor mounts may have issues dealing with the extra torque from the motor. But even then, most use solid mounts and wouldn't even need something like this. I'd say it is a waste of money. The solid link from the motor to your firewall is also going to cause TONS of increased vibration from the motor into the passenger compartment. NOT fun for a daily driver.
BTW...good luck at boot camp! Thanks for choosing to serve our country.
NonStopTuning
Jun 29, 2015 07:42 PM
hampton1100
May 28, 2015 07:32 AM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
