I NEED TO KNOW IF THIS WILL RUB
Old Oct 10, 2004 | 06:26 AM
ksl_redsoxfan's Avatar
Default I NEED TO KNOW IF THIS WILL RUB
i have 18x7.5 wheels with tires that are 215/40/18 and i need to know if thats gonna rub if i drop it 2", and if so will it if i remove the plastic pieces in the wheelwell?
Old Oct 10, 2004 | 06:29 AM
DenZinz's Avatar
it shouldnt, what offset?
Old Oct 10, 2004 | 06:37 AM
i'm not sure what the off set is
Old Oct 10, 2004 | 06:53 AM
DenZinz's Avatar
thats going to be the decidng factor....
do you have a pic of the wheel?
Old Oct 10, 2004 | 07:26 AM
MyBoX's Avatar
Kevin, You should get the goldlines for your silver box and then put these on and test drive the car, that way you know exactly what you should get for your lava !!! Sean
Old Oct 10, 2004 | 07:42 AM
MattyRattyPoo's Avatar
Dude go with a 215/35/18. That's what igot. 40's will rub. Add a 2 inch drop and you'll be stylen!
Old Oct 10, 2004 | 05:43 PM
BLeeK's Avatar
with a 40/18 you may get a bit of rubbing, if you go with a 35/18 then Im confident if you have a goldline esque drop you will not rub...
Old Oct 10, 2004 | 07:37 PM
i want to keep the 40's because it will look sick if i can get it not to rub because it will fill the whole wheelwell and it would look awsome. i think i will have to gut the wheelwell's and i think i should be o.k., if not i can always put the springs on my other xb.
Old Oct 11, 2004 | 07:47 PM
quadoptix's Avatar
just depends on the offset.
Old Oct 13, 2004 | 09:06 PM
BoomBox757's Avatar
DelMarVa
I have 215/35/18 and mine rub on a full locked turn, its all about the offset, mine is 44(?) so thats why
Old Oct 13, 2004 | 09:13 PM
BoomBox757's Avatar
DelMarVa
ohh and I have a 2" drop (spy springs)
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
jtucker7
Apr 8, 2015 05:41 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
