08 Headlight Black Sidemarkers(PICS)
Old Aug 12, 2007 | 12:02 AM
Viace's Avatar
Default 08 Headlight Black Sidemarkers(PICS)
First off I would like to thank Josh from TRD Sparks for getting these to me very fast. The lights are the same as the old ones in baking them apart. The glue to me seemed a little bit stronger. There is no eyelid that can be removed like in the old ones. It comes BSP, this was a plus for me because I always had to paint the eyelid BSP for my preference.
You will need the following things for the project...... A phillips head screwdriver, Gloves ( so you dont burn your hands), needle nose plyers, Silicone(Clear or Black), Rubbing compound, wax, an oven, Plastic spray tint. Cooking sheet pan, damp towell, sand paper for wet sanding, 2000 grit
Before with orange side corners
1. Unscrew the four screws that are along the back of each light with a phillips head scrrwdriver, Place somewhere where you dont loose them.
2. Set your oven to 250 and let it warm up, place damp towell on cooking sheet and place in the oven, Put the cooking sheet with wet towell in the oven and put one head light on the towell.
Now it usually takes 10-12 minutes to soften the glue but it depends on your oven, I checked mine every couple minutes to make sure everything was ok.
3. Put your gloves on before opening the oven to take out the lights because they will be very hott. Take the light out of the oven and pull the light apart.
Put the clear lense on a towell so it does not get scratched.
4. Remove the 2 screws holding the part with the orange reflector and the clear lense cover, and pull the piece out.
Projector from the inside
5. Remove the orange reflector from the housing.
Take the reflector to the sink or somewhere wherewater is because you are going to wet sand it so the tint sticks. I used this tint and it worked very good.
after tinting
Let the tint dry about an hour or so in the sun before sanding it
6. You will need to wet sand the reflector after you have tinted it to get out any imperfections. Following that you will need to use a rubbing compound to get out any swirl marks from sanding then wax it to a shine and clean off.
7. From hear you will want to pop the reflectors back into the housing of the lights.
8. Place the housing back into the clear cover and screw in the two screws you removed earlier.
9. You will need some sicla gel to be safe of any fogging, I always use it and have had zero problems.
Silicone these (about 4 into the backing of the light).
10. Use your silicone and put it into the groovs of the light, where the clear meets the black. front meats the rear. Put the 2 pieces back together and place in the oven again for about 10 minutes.
11. Put your gloves on again because it will be hott, Take the light out of the oven and try to sandwitch it together so all of the little tabs click together. Now let dry because everything should be together now. After everything is cool and dry I like to add some more silicone along the out side of the light just incase.
Do this to both lights and hear will be the out come.
On the car pictures will be posted tomorrow once everything is good to go. 5K Hid conversion kit as well.
Mod Express for all of your Hid needs. Hope this is helpfull
On the car
Pretty good cut off
Old Aug 12, 2007 | 12:27 AM
beerrunninthetc's Avatar
looks really good. But for me it needs something there to big of a black spot for me. But it does look nice im waiting on plans may do it in the future but im waiting for the new car smell to wear off before i start anything.
Old Aug 12, 2007 | 12:32 AM
iKONA's Avatar
I think it looked better before. It looks way too plain rite now.
Old Aug 12, 2007 | 01:09 AM
same thought but im watchimg this one
Old Aug 12, 2007 | 01:24 AM
Jon's Avatar
Jon
Moderator
Moderator
I'm curious as to what's the difference between baking these and baking the 05-07 lights...
Old Aug 12, 2007 | 01:26 AM
Viace's Avatar
Could have gone clear but would have taken to long to make. I wanted the same style as my old ones
Old Aug 12, 2007 | 01:33 AM
FLEA's Avatar
Nice
Old Aug 12, 2007 | 01:36 AM
tCtCtC's Avatar
i agree.... but good job!
Old Aug 12, 2007 | 01:37 AM
shadow12one's Avatar
Can you get a wider shot of the car?
Old Aug 12, 2007 | 02:08 AM
Viace's Avatar
Ya I will tomorrow on the car with HIDs in as well
Old Aug 13, 2007 | 03:37 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Looks great Corey! Can't wait until you do these for my pair when I get em.
Old Aug 13, 2007 | 07:46 PM
TeeCizzle's Avatar
Here's my Custom Blk corner again!..hehe:
Old Aug 14, 2007 | 11:05 PM
Viace's Avatar
nice!!!
Old Aug 15, 2007 | 01:45 PM
Blue_Batmobile's Avatar
Nicely done!
Now, I need an 08 in the San Diego area to make my Sidemarker Overlay. Any takers?
Bat™
Old Aug 15, 2007 | 02:05 PM
ack154's Avatar
Looks like a very nice job... but I'd still prefer my no-bake version.
Not an 08 though, obviously.
Old Aug 15, 2007 | 02:25 PM
TeeCizzle's Avatar
Originally Posted by Blue_Batmobile
Nicely done!
Bat™
Talk to Josh(Flintstone) there a guy named Manny has a 08 silver tC Josh knows who he is!
Old Aug 15, 2007 | 03:19 PM
J-'s Avatar
J-
Looking good, I'll buyem when you get the 09s
Old Aug 15, 2007 | 09:51 PM
hawgs74's Avatar
Props for baking your brand new headlights -- takes ***** -- looks great tho
Old Aug 15, 2007 | 11:08 PM
captainlaziness's Avatar
Looks good but,
Old Aug 16, 2007 | 02:47 AM
Viace's Avatar
I will get better pics soon, thank you for the posative comments, trust me I was nervous as hell baking them open
