storage box illumination
Old Oct 17, 2004 | 05:30 PM
zdawg913's Avatar
Default storage box illumination
has anyone wired the box to a switch so you can turn it on any time? i dont like how it only turns on when the doors are open....
Old Oct 18, 2004 | 05:05 AM
engr's Avatar
Yeah.I hooked up a 7 colour cct along with the cup holders to turn it ON when the tail lamps are ON.
Old Oct 20, 2004 | 01:02 AM
Phantom's Avatar
Default Re: storage box illumination
Yeah I kind of find that annoying that the light only illuminates when any of the doors or the hatch is open....why didn't they wire it so it would light like in the tC when you turn on your headlamps or at least when you opened the compartment door...gessshhhh I'm looking to see if any mechanic is brave enough to venture in and rewire it so it will work the way it should. I'll let you know.
Old Oct 20, 2004 | 05:49 AM
engr's Avatar
They figured that we only need to open the box when the door is opened!!U can actually modify it to switch on when the console is open.Just need to use a different power source and put it thru a normally open limit switch.I have studied the box b4,it is possible to implement,there is enuf space in there.I can give u the colour code of the wiring if u r advanturous enuf to try...
Old Oct 20, 2004 | 07:11 PM
xActoBlk's Avatar
Can you post step by step diy? Thanks
Old Oct 21, 2004 | 04:42 AM
engr's Avatar
I wouldnt mind but i'm now in the process of another mod.. will tty to do this next.. Just hang on first
Old Dec 8, 2004 | 07:20 AM
kyle_husky's Avatar
hi wngr, i want to know how to do it also. I was thinking the storage box light should be turn on when you switch on the CD player. And it should be off when you turn off the CD player. I want to know how to do that so badly...
Old Dec 8, 2004 | 08:27 AM
fugeelama's Avatar
A very, very similar thread was started here:
https://www.scionlife.com/forums/viewtopic.php?t=37455
Mod, please lock this?
Old Dec 8, 2004 | 10:06 AM
engr's Avatar
There is an output to turn on the amplifier if there is any.U can use that line to turn on the LEDs whenever the cd player is switched ON.
Old Dec 8, 2004 | 10:38 AM
kyle_husky's Avatar
can you indicate the "output" you are talking about, engr?
I need step by step instructions....sorry I am a newbie...thanks a lot.
Old Dec 8, 2004 | 01:04 PM
engr's Avatar
How should I put it... not every radio has an output to turn on the amplifier.Each brand has a different wiring table so I cant tell you exactly which one to use.What I can suggest is for u to get the wiring diagrams and show it to me over here.I will help u with that.Would that be ok?
Old Dec 9, 2004 | 08:27 AM
kyle_husky's Avatar
Hi engr, I am using the factory radio/CD player. Any cue?
Old Dec 9, 2004 | 08:43 AM
engr's Avatar
Should have it.But i m driving an ist from japan so i cant be sure which wire it is.U U will still need to get the specs.Our jdm radio is different as well.
yhwhdesign
Jun 11, 2021 03:34 PM
xjleitex15
Aug 17, 2015 12:09 AM
kanundrum
Regional - Mid South
Aug 4, 2015 04:23 AM
