proper 17" wheel tire size for xB?
Old Oct 22, 2004 | 05:04 PM
EAN10775's Avatar
Default proper 17" wheel tire size for xB?
I've seen wheel/tire vendors pairing 17x7 wheels with both 215/40/17 and 205/45/17 tires? which is correct? Thanks.
Old Oct 22, 2004 | 10:38 PM
Old_Punk's Avatar
You'll probably find all the info you need on the Tread and Butter forum.
But to save you the trouble: 205/45-17.
Old Oct 22, 2004 | 10:46 PM
TheScionicMan's Avatar
You may find the info you're looking for in this thread:
https://www.scionlife.com/forums/viewtopic.php?t=31340
Old Oct 22, 2004 | 11:31 PM
RogerTTR's Avatar
Both 205/45R17's and 215/40R17's will work equally well with out creating any problems!
Old Oct 25, 2004 | 08:11 PM
DjBran's Avatar
Has anyone tried 225/45/17? There are alot of potholes in the Bay Area and trying to see if they would fit without lowering the Xb?
Old Nov 4, 2004 | 10:44 PM
CBSIMONSEZ's Avatar
215/45R17s here with no problems. Speedo is exact too.
Old Nov 5, 2004 | 12:55 AM
squirrel's Avatar
don't forget that rim width will have have an effect on the overall tire diameter. I have 215-40/17 on a 7.5 wide wheel. according to the police radar trailer that was on my street, the speedo was close enuff.
Rememeber, speedometers are only an approximation. Tire pressure and tread wear are also factors. The only true reading is by getting calibrated at a speedo shop.
IIRC, the speedo in my Crown Victoria was 2 mph faster than actual.
Old Nov 5, 2004 | 06:13 PM
Prettym1k3's Avatar
Wheel width, sizes, and offsets will all play a prat in the correct tire sizing on your car.
If you're gonna' run a 16x8" wheel, you'll want to stretcha little, and you'll be able to run a larger tire.
But for a 17x7 or something, 205's or 215's is plenty.
I ran a 17x10 (-20et-) on my Mk4 Jetta, with a 235/40-17.
The factory wheel sizes are 15x6.5 with a 35et and like a 195/65-15.
Just size it up, and be smart. You'll be just fine.
scionlife
371
Jun 2, 2015 11:00 PM
foxSCION
13
Dec 3, 2003 05:40 AM
finn_mick
20
Oct 31, 2003 12:17 AM
scioninla
Oct 30, 2003 08:01 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
