Wiper Fluid spray???????
Old Oct 22, 2004 | 11:13 PM
Sciowan's Avatar
Default Wiper Fluid spray???????
Whenever I use my windshield wiper spray, it sprays down the drivers side door after it runs off the windshield. Is this normal or are my sprayers out of adjustment?
Old Oct 22, 2004 | 11:58 PM
jct's Avatar
jct
normal, my Xa does the same thing
kind of makes me mad some times after you wash your car you go driving, then all the bugs all over the front window then you clean 'em with the washer fuild...
and you know the rest of the story
Old Oct 23, 2004 | 10:29 AM
Soon2BxB's Avatar
my box does the same thing ...
try to use em when you are going slower or stopped .. or dont put too much fluid on the windows...
that will help minimize the problem
Old Nov 1, 2004 | 06:32 AM
fireballfish's Avatar
if you don't like where they spray, adjust them. all you have to do is insert a pushpin into the little ole and push in the desired direction... I had this problem once after installing aftermarket nozzles
Old Nov 2, 2004 | 09:31 PM
iowagary's Avatar
I don't know what Scion you're referring to, but the tC manual says specifically to NOT put a pin or anything else in the sprayer nozzle. You'll end up with a stream of fluid instead of a spray. Check it yourself - I think it's in reference to what to do if you clog the nozzle up. Anyways, don't adjust it like that.
Old Nov 8, 2004 | 10:41 AM
nataku009's Avatar
what about the back window my box has that constent stream running down the back of the car and of course the dealerships are no help they still can't figure out the paint problem
Old Nov 8, 2004 | 03:06 PM
iowagary's Avatar
The tC has no back window, but I assume all the sprayers are the same. Honestly, if your dealership sucks that bad, it's time to start taking your problems to a different dealership. I'd assume that the nozzle is both a simple part and an easy to replace part. It's also unlikely that they'll say it's fixed if it isn't. You should be able to call them up so they know you're coming, drive down there, and possibly have them fix it on the spot, depending on how busy they are and how good of a dealership they are. Honestly, nothing is going to get fixed if your dealership sucks so you stop using your warranty. Get that thing fixed, then post what they did.
gqdabien
Oct 8, 2015 05:36 PM
olyellr
Sep 28, 2015 10:32 PM
Xaphoon
Sep 21, 2015 02:18 PM
excessads
Sep 15, 2015 05:28 PM
ScionDP
Sep 8, 2015 02:17 AM
