Maint Reqd light
Old Oct 22, 2007 | 07:13 PM
ominousinc's Avatar
Default Maint Reqd light
All,
I just turned 5k on my xB2. The maintanence light came on, and stays on. I was wondering how to turn it off. DO I have to disconnect the battery cable for a bit? I was hoping I wouldn't have to lose all of my fuel data, and am wondering if all of that will go away when I reset.. Any advice would be appreciated.
Old Oct 22, 2007 | 09:55 PM
TerribleTed's Avatar
Not sure about the 2nd gen. Might be the same as the first gen. On the first gen you make sure that the odometer is displayed, turn off the ignition, press and hold the odometer rest button and then turn on the key, wait a few seconds and then light resets. A number of cars use similar maint light resets (my wifes Honda is essentially the same). There may be instructions in the owners manual, if not call the dealer , mine gave me the instructions over the phone.
Old Oct 22, 2007 | 10:01 PM
draxcaliber's Avatar
it is just a timer to remind you to change your oil. so everytime you change your oil, start the car while holding down the button next to the odometer and wait for a line of dash's to appear, and disapear one at a time, once that has happened, it has been reset.
Old Oct 22, 2007 | 11:44 PM
ididntdoit5150's Avatar
if it is like my old toyota which im sure it is exaclty the same, you make sure the odo is dysplayed, not the trips. turn the ignition on and hold the odo reset button for up to ten seconds. you will see 5 little dashs, keep holding the button and it will count down to 1 then 0 and reset the maintnence required light
Old Oct 23, 2007 | 12:12 AM
avus's Avatar
^^^ what they said
the reset procedure is that same on our xBs
just recently reset mine
Old Oct 23, 2007 | 02:25 AM
Whispaz's Avatar
i know, get an your oil changed by scion..... bye bye light
Old Oct 23, 2007 | 05:06 AM
ScionFred's Avatar
First of all, get your oil and filter changed ASAP, if you haven't already.
Second, change the odo display to 'trip A' and turn the ignition to 'off'. Hold the trip reset button down, turn the igntion to 'on' and wait 5 seconds. The maint-req lite has now been reset for another 5000 miles
It's all on page 99 of your owners manual...
Old Oct 25, 2007 | 03:17 AM
ya and if you are at 5000 miles i hope you have changed your oil and filter.
Old Oct 25, 2007 | 03:40 AM
Invertalon's Avatar
I'm doing my comp. services at 3500 & 7000, then start my own oil changes at 11,000 then at 15000 and every 5k after that.
I couldn't get myself to wait for the 5k service, so ill do the first two sooner then move onto 4k then 5k.
Old Oct 30, 2007 | 01:19 PM
JRT's Avatar
JRT
what wt oil are you using the book states 0-20 w or 5-20w ?
xBSciontist
Jun 18, 2019 03:06 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
