axle back exhasut?
Old Nov 13, 2007 | 01:22 AM
Sieruc06TC's Avatar
Default axle back exhasut?
is there any performance with an axle back exhaust...or do i have to change out the s-pipe and mid pipe to get performance..???
Old Nov 13, 2007 | 01:25 AM
whiteshirt's Avatar
DeepSouth Scions
Out of an axleback, you should expect maybe 2 or 3 whp, nothing noticeable. And even with an spipe and midpipe, you may gain just a little hp, but you may not get it where you want it, i.e. it shifts the power to one specific part of the power band.
Old Nov 13, 2007 | 01:30 AM
Sieruc06TC's Avatar
ahh allrite thanks....
Old Nov 13, 2007 | 05:07 AM
unxpectederror's Avatar
some axle backs will give you upward of 6whp
some of the less flowing designs such at the TRD will most likely net you around 3whp though
Old Nov 13, 2007 | 11:30 AM
sciontc08's Avatar
im getting a custom cat-back system made...its way cheaper then buying an axle back
Old Nov 13, 2007 | 08:40 PM
CuRiOuSfIsH's Avatar
Hmmmmm........ maybe there are gains but butt dyno wont show much.
Old Nov 13, 2007 | 08:45 PM
frankie_j_'s Avatar
my advice...
by the nts pulley kit, should feel summin there
Old Nov 13, 2007 | 09:48 PM
sciontc05123's Avatar
an axel back should give u about the same HP as a neon under your car. I like the pulley kit idea though but it is alot harder to put on if u r planning to do it yourself. You will need an air wrench. If u have a few hundred bucks my advice is an intake and springs!!
Old Nov 13, 2007 | 11:06 PM
Mid_Life_tC-risis's Avatar
If you don't take advantage of the SEARCH feature you won't get the full benefits of this site ...
A straight-through axleback muffler has been shown to give 5-6whp gains on a manual tC:
https://www.scionlife.com/forums/viewtopic.php?t=80070
Replacing the s-pipe & midpipe is a waste of money IMO, unless going turbo (where you will NEED to move up to a 2.5" exhaust.) Putting on a 2.5" s-pipe and midpipe on a naturally-aspirated tC will only serve to kill your low-end torque.
dbg326
May 31, 2015 05:29 PM
bktply
Mar 17, 2015 04:50 AM
carid
Feb 9, 2015 01:49 PM
snappe2
Jan 27, 2015 05:29 PM
DjFrOsT
Dec 13, 2003 04:18 AM
