Dual exhaust exit from the sides
Old Nov 19, 2007 | 04:55 AM
driveonfishboy's Avatar
Default Dual exhaust exit from the sides
I am thinking of my next mod and have done some investigating. I want to run duals exiting just in front of the rear tires. I would pocket the side skirt or cut a section out sort of like "ELENOR" on gone in sixty seconds. Clearance has been a problem. I have attached a pipe there to check clearance and it is too close. I thnk I can address this with a larger pipe flatened into an oval for clearance and flow. I may even consider a rectangle section spliced there. Problem is the skirt. It doesn't allow me the space to pocket it. Has anyone attempted this? Would another skirt work? I'm working on it but my prospects look dim. Any info would be appreciated.
Old Nov 19, 2007 | 09:52 PM
kzhorse's Avatar
Strictly Scionized
I thought of that also but not enough room so I did it a different way.
Scott
Old Nov 20, 2007 | 12:50 AM
low_down_xb's Avatar
i did mine but i only did it on the passanger side becasue thats the way the pipe angles out, i used 1.5x3" tubing and it worked well, tucks right under the sideskirt, so i went back and made a dual tip so it looks better, just need to weld it on
Old Nov 20, 2007 | 05:14 AM
kzhorse,
Thanks for the reply! Doesn't that take up more room than pocketing the skirt? I ran a pipe flush against the body and had issues moving from an incline to flat ground. I got contact just past high center. Don't you have any problems? What size pipe is used to crossover? That looks pretty wild.
Old Nov 20, 2007 | 05:16 AM
Hey low down,
you got any pics of that mod? Thanks.
Old Nov 20, 2007 | 09:37 AM
Nick06tC's Avatar
I saw it on a xB at HIN this year. Its Adams car (I think that is his name. I am bad with names and have met hima few times), I thought I took pics of the side, but I guess not. But if you can find more pics of this ride, then you can see it.
Old Nov 20, 2007 | 11:40 AM
kzhorse's Avatar
Strictly Scionized
Originally Posted by driveonfishboy
kzhorse,
he pipe where it y's off is 1 1/4 maybe this will help some more pictures.
cott
Old Nov 20, 2007 | 09:04 PM
Gothbox's Avatar
watching...
I want to remove the side skirts and run some "lake pipes" I have seen a bB with them and I like it.
Old Nov 20, 2007 | 10:55 PM
dmpsk8's Avatar
i have considered this before, but was too lazy to follow thru
Old Nov 21, 2007 | 05:09 AM
The pics of kzhorse's car has got me re-motivated. I'm thinking of a rectangle pocket housing a rectangle stainless tip. I guess the next step is to remove the skirt but I think I'll try to find a damaged junker first. That way I can cut it and not worry if it don't fly. I still would like to see someone with it already cut out and done.
Old Nov 21, 2007 | 11:20 PM
OC_ScionBox's Avatar
why would you do this to a scion??
its ridiculous!!
i understand having side pipes like on a truck
or a mustang, but an Xb????
Old Nov 22, 2007 | 02:12 AM
^^^ because we are different, sorry if you dont want to be that way, you can stay with the other cookie cutters, and just blend in with the crowd
Old Nov 22, 2007 | 02:25 AM
BangorXB's Avatar
yeh adams pink xb has the exhaust notched and running down the side skirts
Old Nov 22, 2007 | 07:47 AM
There are several xbs with duals. What's the diff just because it's out the side? I think that it would look pretty cool. If you don't, then don't do yours. Pretty simple.
Old Nov 23, 2007 | 04:23 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
i'd love to see dual axel back's out the side
like on the M3 GTR
Old Nov 24, 2007 | 05:37 AM
xoBkcalb's Avatar
Something like this.
Old Nov 24, 2007 | 06:55 AM
WHOA!! Hold the phone! I like that. Who's car is that? If that belongs to anyone watching, send the details. THAT IS COOL!
Old Nov 24, 2007 | 07:04 AM
Skuff_Box's Avatar
The silver two tone is HOT! Love how the side exhaust actually looks nice. Anyone have more info on it?
Old Nov 24, 2007 | 08:18 AM
xoBkcalb's Avatar
He doesn't really hang out on the forums. It sounds real sick and he beats the pi$$ out of it.
I will se if i can get some info on it from him. He owns a shop in my area called Grafx they do all sorts of insane custom vinyl. Plus he is a cool guy so he would most likely be forthcoming with the info.
Old Nov 24, 2007 | 03:56 PM
TastyTuner's Avatar
more pics of the pink xB's engine bay!!
