The HTPC C.E.L. Fix
Old Jan 22, 2008 | 04:50 AM
x_Batman_x's Avatar
Default The HTPC C.E.L. Fix
I know that many of us tC owners end up having to fight an epic battle against the CEL upon installing headers or a turbo. Since installing my DC sports header I tried 2 non-foulers, 3 non-foulers, and this thing: https://www.scionlife.com/forums/vie...210&highlight=
I developped a new solution and it has been working great for me: the HTPC (High Tech Pepsi Can) fix
I am not responsible for what you to your car yadayadayada and also it is very important that you use a Pepsi can Coke or Sprite will screw the whole thing up!
moving on basically the concept is to make the hole smaller so that less exaust gasses pass through the non-foulers to the O2 sensor. One could weld a metal bead onto a non-fouler to make the hole smaller, but this is cheaper and you get to enjoy a fizzy, sugary, beverage.
You need a standard non-fouler fix, ie a drilled out nonfouler, screwed into a normal one:
Now get a 3rd non-fouler and grap a can of Pepsi:
Start by drilling a small hole in the bottom of the can, a 7/64"or a 1/8" drill bit should work fine:
Now get a sharp pair of scissors, and begin cutting your can, be very careful, aluminum can be sharp!
continue cutting like so:
basically you want to end up with a small square piece of aluminum with the small hole in the center:
trim the square so that you can drop it into your 3rd non fouler:
and screw the original two into the third one, when in installed it should go like:
O2 sensor - drilled out non-fouler - regular non-fouler - aluminum piece - regular non-fouler - S-pipe
Notice how much less light can pass through this setup:
I hope this works for those of you that the standard non-fouler trick did not work for, and do not forget to properly reset you ECU.
Old Jan 22, 2008 | 04:58 AM
jct's Avatar
jct
just be careful with it and not cut your self
Old Jan 22, 2008 | 03:06 PM
bigwillystyle23's Avatar
what if you put the secondary o2 sensor in an antifouler that was completely welded shut to close off all the gases?
Old Jan 22, 2008 | 03:40 PM
Mid_Life_tC-risis's Avatar
^^Doing this would probably throw a CEL - for a different fault. The ECU compares the outputs from both sensors, looking for small voltage changes from the second, in correlation with output changes from the first sensor (AFR). Since the 2nd sensor would now show a steady output - since it's not exposed to the exhaust stream - the ECU would think that 2nd sensor was faulty.
Old Jan 22, 2008 | 03:56 PM
damn! just when i thought i had it all figured out... DAMN YOU TOYOTA!
Old Jan 22, 2008 | 11:41 PM
x_Batman_x's Avatar
Yes you will throw a different fault code. I had wondered the same thing too. Now what would be effect would be to weld one shut and then drill a small hold, thus acheiving the same result as my Pepsi can fix. If you can weld go for it, if you can't, do the can fix to save yourself money/effort.
Old Jan 23, 2008 | 01:19 AM
i was thinkin about this today. instead of aluminum from a pepsi can you could take a washer with a small hole in the middle and put it inbetween 2 antifoulers.
Old Jan 23, 2008 | 01:33 AM
x_Batman_x's Avatar
hey if you can find a washer with a small hole that can fit between the 2 non-foulers, go for it; what ever gets the job done, let me know how it goes.
Old Jan 23, 2008 | 03:13 AM
NoLimitzBuilt's Avatar
Team No Limitz
Why not just buy the CEL eliminator and make it alot faster and making sure it works.
http://www.nolimitzind.com/cel.html
Old Jan 23, 2008 | 03:30 AM
Tc4Eva's Avatar
Team ScionTific
I might sound like a noob, but if you used a scangauge, couldnt you just clear the code?
Old Jan 23, 2008 | 05:02 AM
yea but it keeps coming back. to pass emissions you must have a clean record of no CEL's over a period of time.
that check engine light eliminator looks like it just might work really good.
Old Jan 23, 2008 | 01:18 PM
Team No Limitz
It does work good, I used one on my tC for over a year and a half with no issues what so ever. I tryed the anti fouler things you guys are doing and eventually it comes back. This fixed it for good.
Old Jan 23, 2008 | 09:18 PM
x_Batman_x's Avatar
I will be the first to admit my solution is ghetto, however it isnt $45 bucks. So why not try my idea and use the money you saved to get some cathodes.
Old Jan 23, 2008 | 09:43 PM
Tc4Eva's Avatar
Team ScionTific
I gues ill have to get the anti fouler then... anyone know if it works well for the megan racing header?
Old Jan 24, 2008 | 02:16 AM
Team No Limitz
The CEL Eliminator works with all the headers.
I do agree the the first one is cheaper. Hell I tryed it long ago. But eventually ended up buying the right one. Just depends on how many times you want to mess with it trying.
Old Jan 24, 2008 | 03:57 AM
Tc4Eva's Avatar
Team ScionTific
Ok, Thanks I guess ill get it when im ready to put in my headers.
Old Feb 8, 2008 | 04:48 PM
thumper_1151's Avatar
works great
jnesselroad
Sep 15, 2015 06:57 AM
elwaylite
Aug 9, 2015 09:21 PM
5N1PE5
Aug 3, 2015 11:25 AM
Scionxa180
Jul 31, 2015 03:47 AM
sgetchius143
Jul 28, 2015 09:55 PM
