piping
Old Jan 23, 2008 | 12:51 AM
azureloki's Avatar
Default piping
what kind of pipes are okay to change to aftermarket(reworded)
Old Jan 23, 2008 | 12:54 AM
draxcaliber's Avatar
talk about dumb questions...
Old Jan 23, 2008 | 01:15 AM
SquallLHeart's Avatar
... neither.
Old Jan 23, 2008 | 01:16 AM
bigwillystyle23's Avatar
straight pipe is a lot louder. you might be okay if you never got an aftermarket header.
Old Jan 23, 2008 | 01:57 AM
in this case, it is pretty much the same thing. an aftermarket mid-pipe wouldn't have a secondary catalytic convertor, and probably not a resonator, but some do.
Old Jan 23, 2008 | 02:38 AM
azureloki's Avatar
i see, so just changing the mid pipe is not okay? as i changed above.
Old Jan 23, 2008 | 02:55 AM
no, nothing wrong with changing the mid-pipe is fine, but in your case, you were pretty much asking about making a decision about the same thing.
anyway, your exhaust is 4 sections of piping in this order from your engine to the butt of your car:
header, s-pipe, mid-pipe, axelback.
you have a catalytic convertor in your header, any aftermarket header will mean you have no primary catalytic convertor.
then is your s-pipe, it is a crush bent restrictive peice of exhaust shaped kinda like the letter "S" so a smoother wider mandrel bent one would be better.
your mid-pipe has a secondary catalytic convertor on it, not as big as the one in the cat, but there is one there, also, it has a resonator, and a few little bends. replacing this will elimate the second cat, and a mandrel bent one will be less restrictive.
lastely you have the axelback portion, which is basically a muffler, replacing this with a less restrictive, better angled exhaust would make it better.
so when you ask "which is better, a straight pipe or a mid-pipe, they would pretty much replace the same part. of your exhaust.
Old Jan 25, 2008 | 08:52 PM
weslxa's Avatar
Headers obviously give a nasty rasp, but would replacing the mid pipe with just a straight pipe eliminate any of the rasp, or would a resonator be a better route to go?
Old Jan 25, 2008 | 10:01 PM
azureloki's Avatar
resanator
Old Jan 25, 2008 | 10:19 PM
weslxa's Avatar
So, straight pipes would probably make it worse?
Old Jan 26, 2008 | 03:43 AM
correct, because the reason for the rasp is that there are less things absorbing the sound made by the engine and the exhaust. i.e. the catalytic convertors in the header and the mid pipe, and the resonator on the mid-pipe. so if you get rid of those, you need some good resonators to absorb the noise.
Old Jan 26, 2008 | 04:20 AM
two0sickness's Avatar
does any one know how megan's mid pipe is...
SloTC1
Aug 16, 2018 02:45 PM
RS2Blitz
Jan 15, 2016 09:42 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JLOVE1
Jul 31, 2015 02:40 AM
