verification on offset
Old Jan 23, 2008 | 04:34 AM
agarick's Avatar
Default verification on offset
I know this has been kicked around this forum for awhile but I can't really discern a definite answer. I want to buy a certain wheel. 17X8. Wheel comes in either 35 or 48 offset. From what I can tell from the postings is that the 35 offset would/might work and be most flush. Would the 48 offset be too much? Would the 35 offset rub at all? Sorry if the answer is out there and I missed it.
Old Jan 23, 2008 | 01:25 PM
Big_Jim's Avatar
From what i've been reading, the stock offset is 39. If you run the 35et wheel, it will push the wheel out less than a quarter inch.
the 48 would tuck the wheel in more.
Old Jan 23, 2008 | 05:06 PM
playindagamewell's Avatar
OhioScions
i have +35's and all is well with them... you can see some pix in my sig of my car or if you want more i can probably post
Old Jan 30, 2008 | 05:10 PM
Tamago's Avatar
yes but that's on a 6" wide wheel.. your effective "poke" on a 8" wide +35 compared to stock 6" +39 will be 1.15" of "out"
Old Mar 17, 2008 | 10:32 PM
DiscountTireDirect's Avatar
17x8's should work as long as the offsets are within 28-41mm. The 35mm should work great.
Old Mar 17, 2008 | 10:38 PM
OhioScions
it does thanks for the reply
Old Mar 17, 2008 | 10:52 PM
Good looking setup Playin, nice work.
Old Apr 30, 2008 | 11:05 PM
TheJonas53's Avatar
I want to do a 17x8 35 offset set up but im running with Tanabe DF210s. I know playindagamewell is using a TRD spring set up and has no issues. Can I even do that set up with the suspension I am running? And what tire size would I be looking into?
Old Apr 30, 2008 | 11:51 PM
Should be ok Jonas, look at the 225.40.18 for the size. It would be a hair shorter than stock but it should fit like a glove. If you want to look at the 235.40.18's look into some of the narrower running brands like Falkens.
Old May 1, 2008 | 02:56 AM
TheJonas53's Avatar
Im not doing 18" wheels im going with 17" wheels but 8"wide. So you mean like 225/40R17 then and I shouldent have a rubbing issue?
Old May 1, 2008 | 12:15 PM
Tamago's Avatar
that's much too short of a tire, it'll look really dumb IMO..
shoot for a 45series tire
Old May 1, 2008 | 08:12 PM
My mistake, the 225/45R17 will work nicely.
Old May 4, 2008 | 05:32 AM
jspectoaster's Avatar
hey jonas i got 17x8's +35 comming i'll let you know how it goes.my 18x8.5 +35 was rubbing bad on df's
Old May 16, 2008 | 12:43 AM
katchkillah's Avatar
any updates on the 8's?
xBrelease08
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
