verification on offset
I know this has been kicked around this forum for awhile but I can't really discern a definite answer. I want to buy a certain wheel. 17X8. Wheel comes in either 35 or 48 offset. From what I can tell from the postings is that the 35 offset would/might work and be most flush. Would the 48 offset be too much? Would the 35 offset rub at all? Sorry if the answer is out there and I missed it.
Originally Posted by Big_Jim
From what i've been reading, the stock offset is 39. If you run the 35et wheel, it will push the wheel out less than a quarter inch.
the 48 would tuck the wheel in more.
I want to do a 17x8 35 offset set up but im running with Tanabe DF210s. I know playindagamewell is using a TRD spring set up and has no issues. Can I even do that set up with the suspension I am running? And what tire size would I be looking into?
Should be ok Jonas, look at the 225.40.18 for the size. It would be a hair shorter than stock but it should fit like a glove. If you want to look at the 235.40.18's look into some of the narrower running brands like Falkens.
shoot for a 45series tire
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
umnitza
Sep 1, 2015 08:06 PM
