whats y'all use
Old Nov 15, 2004 | 09:43 PM
jct's Avatar
jct
Default whats y'all use
what kind of floor jacks for y'all use
i know i can't use my dads floor jack on my xA cause its too damn big and the car sits low enough as it is (stock highth)
and whats a good cheap jack to get
i don't want no sizors jack either those suck and same with the torpeedo(bottle) jacks too...
Old Nov 17, 2004 | 12:49 AM
lonewolfxb's Avatar
i made some short ramps out of 2x6 lumber,about 18" long,they work fine. hope this helps.i have the big garage floor jack.
Old Nov 17, 2004 | 02:47 AM
id say get the napa low jack or the craftsman aluminum jack the chrome and red one not the all red one. expensive but pretty low and good. i'm lookin for one with a a saddle thats lower than 3 inch. like 2.75 or 2.5 will clear all of my cars so. i'm on the look out.
Old Nov 17, 2004 | 03:32 AM
TheScionicMan's Avatar
I bought a decent little floor jack at WalMart for about $15. It's low enough to get under and I'm down 2 inches. ALso buy a pair of jackstands. Besides the safety factor, they make it easy to do things to both sides instead of moving the jack back and forth. You only need a 2 ton jack, I haven't seen any smaller than that anyway.
One of the things I thought was funny is that most of the jacks touted a feature to lift the arm all the way up to the jack point with one stroke, but I can't even use it cuz it's already almost there...
Old Nov 17, 2004 | 03:53 AM
squirrel's Avatar
I made some wooden ramps out of 2x6s. I double stacked them, angled cut, the bottom piece is 3 feet long, and the top piece is 18 inches long. That way I can fit my 3 ton Napa floor jack under it. I also have four 2-ton jackstands
Old Nov 20, 2004 | 10:55 PM
lonewolfxb's Avatar
the squirrel and tha wolf have it gonning on,read our post, if you want to buy tha high dollar jack then go for it we are putting our jack into other mods,right squirrel.
tha wolfman..
Old Nov 21, 2004 | 01:44 AM
$15 is high dollar?
Old Nov 21, 2004 | 11:48 AM
yes. yes it is., lol i make due with a pair of toyota scissor jacks . easier to get under the los sides of the car. and with that built in rear center lifting point. very easy and convenient.
Old Nov 22, 2004 | 02:35 PM
panasoanic's Avatar
I am not sure with the xB, but on the tC, there is a jack point front and center of the engine. However, the jack point itself is in the shape of a raised oval. I am not too confident in using that jack point with a standard puck shaped jack. Is there some sort of adapter plate that we can put on our jacks to get more secure connection between the two?
Old Nov 26, 2004 | 06:27 PM
4rjn's Avatar
I am using regular stands but very careful where to place them
