Spring Install Problem, Joint Popped Out.
Old Nov 17, 2004 | 02:29 AM
sanders's Avatar
Default Spring Install Problem, Joint Popped Out.
help! everything was going smoothly with my spring install... and this just so happened on the last when i was putting everything back together.
i was attempting to put in the two bolts which attach to the brake/wheel assembly... and i think i accidentally ended up popping out the axle which connects to the transmission. now the brake/wheel assembly is leaning at an angle and is no where close to getting attached back to the strut. how do i fix this? i'm working on getting pix up. thanks in advance.
please view pix here... https://www.scionlife.com/gallery/sh...00&ppuser=7482
--chad--
Old Nov 17, 2004 | 02:41 AM
pop it back in with it straightened. i had mine pop out once or twice.
Old Nov 17, 2004 | 02:46 AM
sanders's Avatar
any trick to just popping it back in?
Old Nov 17, 2004 | 02:48 AM
just grab ahold of the axle and push it straight in. it should kind of click once back in. make sure it meshes. you'll know if it's meshing or not. it's no worry man. good luck . pm me if u need more detail
Old Nov 17, 2004 | 03:02 AM
sanders's Avatar
got it in.... thanks! i think i just ran out of energy... and me sitting here at the computer and then going back made the difference! thanks for the help!
Old Nov 17, 2004 | 03:03 AM
lol. welcome. take it easy if you were to accidentally yank one out u could get screwed. it's all good tho. take it easy. and have fun with the rest of the install
Old Nov 17, 2004 | 04:36 PM
don't worry abouyt it, the axle poping out has happened to the best of us. And its not a big deal, but now you have the experience to handle the situation. Good Job!
Old Nov 17, 2004 | 04:40 PM
squirrel's Avatar
Just make sure you don't tear the rubber boot around the uni joints. And you're good to go.
Old Nov 17, 2004 | 04:53 PM
exactly
Old Nov 17, 2004 | 04:59 PM
squirrel's Avatar
See, I told you I don't know squat about Scions.
Old Nov 17, 2004 | 05:21 PM
see, I told you I don't know squat about scions.
Liar!!
Old Nov 17, 2004 | 05:29 PM
squirrel's Avatar
Liar!!
I don't, I don't. I'm just a crippled old man, watching his two year old son run everywhere!
Old Nov 17, 2004 | 08:28 PM
inevitablegod's Avatar
weve been able to pull of three spring installs so far without that problem, but it is something i remind everyone of when we start on each install. glad you got it done without further problems. no doubt you will enjoy the new ride.
Old Aug 26, 2006 | 02:18 AM
JDMRyde's Avatar
Default old thread
Ok...I know this is an old thread but after searching i found someone else who ran into the same problem as me.
I just installed my springs and struts but ran into this same problem...
It seems like i got it back in and the rubber isn't torn but a handfull of the greasy liquid dripped out. My question is...Do i have to get the fluid filled up again or can i continue driving without taking it to a shop???
Old Aug 27, 2006 | 06:26 PM
JDMRyde's Avatar
Default xb
bump!!!
Old Aug 29, 2006 | 06:05 PM
Default Re: old thread
If it was liquid only, do not worry about it. The just fluid from the grease gel.
scionlife
10
Mar 1, 2016 09:14 PM
hampton1100
Jan 2, 2015 08:13 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
ccXB
9
Oct 15, 2003 02:55 PM
