TRD tune for Supercharged tC 06 and 07 whats the difference?
Old May 30, 2008 | 04:52 AM
JDMscionTC85's Avatar
Default TRD tune for Supercharged tC 06 and 07 whats the difference?
I know that the ECU's are tuned different for these years. However is the TRD reflash also different for the supercharged 07 and 06 tCs??
Old May 30, 2008 | 04:56 AM
1_kLEan_tC's Avatar
No.....
Old May 30, 2008 | 01:26 PM
so the trd flash program for the superchargers are the same for both years??
Old May 30, 2008 | 01:45 PM
1_kLEan_tC's Avatar
Well pretty much the are some very minor differences since the 2007 motor is difference than the 2006....but you can plug in 2006 ecu in 2007 tC.
Old May 31, 2008 | 12:41 AM
does it run without problems?? for the trd s/c flashed ecu
Old May 31, 2008 | 01:39 AM
1_kLEan_tC's Avatar
You must get your ECU reflashed!
Old May 31, 2008 | 02:10 AM
imsonofagun's Avatar
I'm not sure where you got your info from, but the 05-06 tC's use a one time use a module supplied with the supercharger and a digital transfer device the dealership has for the reflash. For the 07+ the dealership downloads the Calibration Update into the Toyota Diagnostic Tester Tool using the TIS Calibration Update Wizard. The Diagnostic Tester Tool is then connected to the ECU. There is no module for the 07+ like there is for the 05-06.
See page 29, step 12 for the 05-06:
http://www.trdsparks.com/install/PTR01-21050-90inst.pdf
See page 33, step 14 for the 07+:
http://www.trdsparks.com/install/PTR41-21070inst.pdf
Old May 31, 2008 | 02:19 AM
equinox2355's Avatar
I like having the module, it makes me feel like toyota actually did something
Old Jun 2, 2008 | 07:30 AM
hey equinox is the trd lsd worth it with the sc setup?? I have a trd lsd but not installed. Have to same of the money to get it installed. I am wondering if it was worth the price.
Old Jun 4, 2008 | 10:00 PM
hookedonlucy's Avatar
is there a way to reflash the 06 model without a new module?
Old Jun 4, 2008 | 11:30 PM
2_much_tc's Avatar
nope...
Old Mar 2, 2009 | 03:36 AM
boostedtc1215's Avatar
yes. try and find someone selling there trd reflashed ecu already for your year ti have a 06 supercharged tc and thats what i did.. the trd reflash is capable of running the 9.5 psi pulley no more tho. if you want to run the 12 you should get engine management,
ColonelSanders85
Dec 9, 2020 09:44 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
Halo19boy
Jan 27, 2015 10:19 PM
TheTripleC
Jan 4, 2015 06:46 PM
tbblizzard
11
Dec 5, 2003 12:21 AM
