View Poll Results: 1/4" (roughly 7-8mm) spacers safe?
1/4" is just a tad bit too large. . . don't do it. You may lose a wheel in the process
30.77%
Generic spacers are POS's and you're stupid for even buying them, you sorry sack of. . .
46.15%
1/4" is safe and fine. . . go ahead and use them
23.08%
Voters: 13. You may not vote on this poll
Need help: spacers
Old Dec 7, 2004 | 02:41 AM
djct_watt's Avatar
Team Sushi
Default Need help: spacers
I got a set of generic 1/4in spacers for my rear wheels, to get a more aggressive stance in the rear, they are designed for "compact cars" with a 4 lug setup. . . but I would like to poll you guys for your opinions. BTW, these are the spacers that go over the studs, rather than extend the studs themselves.
I know generic spacers are stupid. . . but the gap is annoying, and I can't justify paying $50+ for hub spacers to move the wheels a few milimeters. . .
Old Dec 7, 2004 | 02:46 AM
BoomBox757's Avatar
DelMarVa
seems good enough for me, whats a quarter inch when you have one to spare?
Old Dec 7, 2004 | 02:51 AM
squirrel's Avatar
See my other post below.
Old Dec 7, 2004 | 02:52 AM
abbfanuc's Avatar
1/4" is 6.35mm. Just a tad too thick. I would get extended lugs. The H&R comes with them so i would use them just to be safe. Remember you are losing 6.35mm of stud when you are using those spacers.
squirrel's Avatar
I would check the length of the wheel studs first. You'll need to have at least 6 full rotations, or you're going to loose a wheels or two, and possibly get hurt.
If you want at least 1/4 inch of spacing, you're better off w/ Van's rear spacing shims in the rear.
Oh, this is for xB and not sure if it'll work w/ xA or not. I'm not a Scion expert.
Old Dec 7, 2004 | 03:10 AM
i had these same type spacers on the rear of my bmw. they worked fine for awhile. until one day heading towards cal-expo. my car was wobbling and by the time i stopped to turn onto fair oaks from watt oncei finally came to a stop my rear drivers side tire came off. luckinly i was at a stop and nothing bad happened.(other than being late for work and gettin the ____ scared outta me) i'd say make DAMN SURE there is at least 6 turns. OR ELSE. ask for some damaged shims maybe van has some laying around. save up bro. i gotta save up for air bags u gotta save up for rear wheel spacers. ok? OK!! peace
Old Dec 7, 2004 | 03:11 AM
djct_watt's Avatar
Team Sushi
cool cool, thanks guys. . . keep the replies comin!
djct_watt's Avatar
Team Sushi
so 6 full rotations, and I'm good?
Old Dec 7, 2004 | 03:16 AM
yeppers
Old Dec 7, 2004 | 04:19 AM
squirrel's Avatar
At LEAST 6 rotations. That way when they are torques down, they won't loosen or strip out.
I'm not an expert on anyting that has to do w/ cars let alone Scions.
Old Dec 7, 2004 | 06:31 PM
dgHotLava's Avatar
its too much, without getting longer studs....
don't risk it, be safe, get the longer studs then do it...
Old Dec 7, 2004 | 07:18 PM
djct_watt's Avatar
Team Sushi
only 4 votes?
Old Dec 7, 2004 | 07:41 PM
TheScionicMan's Avatar
Check out the videos on OTG about generic spacers:
http://onetongarage.com/products/whe...cer/index.html
IMO, the attachment of your wheels to your car isn't an area to skimp on... skimp somewhere else.
Old Dec 8, 2004 | 01:51 AM
djct_watt's Avatar
Team Sushi
All in all, I think I agree.
Old Dec 8, 2004 | 02:41 AM
I also agree.
Old Dec 8, 2004 | 03:24 AM
squirrel's Avatar
Everytime I have the $$$ for van's spacers, he's OUT!
Old Dec 8, 2004 | 03:27 AM
BoomBox757's Avatar
DelMarVa
does your sign say noob? that is so not true
Old Dec 10, 2004 | 03:45 PM
squirrel's Avatar
According to some so-called "experts" I've gotten PM and replies from, I am.
Old Dec 10, 2004 | 03:49 PM
BoomBox757's Avatar
DelMarVa
haha what a bunch of losers, they are just hating cause you car kicks ___
Old Dec 10, 2004 | 04:32 PM
squirrel's Avatar
Thanks Will!
Its sort of in the middle of a major make-over right now. The hood and wing are on, and I still have a few pieces sitting in the garage. Not too mention a few pieces that are on order.
