need some help with lowered box
Old Jul 28, 2008 | 06:33 PM
fztcar's Avatar
Default need some help with lowered box
Hello. I dropped my box on Tein S-Techs this weekend and was told I now need to get an alignment on the wheels. I went to three different places today and got extremely different price quotes. The first place (Tires Plus) said I needed camber kits plus the alignment and it would run me $360 for 4 hours of work. The 2nd place (Beaumont Alignment) said a camber kit was probably not necessary and they could do it for between $70-95 (assuming it wasnt too low for them to get onto the ramp...), and it would take less then an hour. And the third place was Midas and they said that it could go either way and i needed to get the specs from the companys website (Tein USA) before they could quote me better. Oh and I went to a 4th place (Car X) and they refuse to do an alignment on lowered vehicles.
So now my question is, what actually needs to be done to my box for an alignment after dropping it aproximatly 1.5 inches? And which of these places would you suggest taking it to? Im just confused and dont want to end up overpaying for something I dont need.
Thanks for your help.
On a side note, love the look of it lowered...
Old Jul 28, 2008 | 06:41 PM
PhillyCamoBox's Avatar
um you shouldnt need anything at all camber wise... 360$ wow
Old Jul 28, 2008 | 07:41 PM
MadMike550's Avatar
bring it to beaumont
Old Jul 28, 2008 | 07:44 PM
burstaneurysm's Avatar
An alignment shouldn't cost more than $80.
Your camber shouldn't be too out of whack on S.Techs. If anything, the only thing that would likely need adjustment is the toe. The rear wheels are pretty much non-adjustable, so you're only really talking front wheels.
Tell Tires Plus to eat it.
Old Jul 28, 2008 | 07:46 PM
ShockTherapy's Avatar
X2
i took mine to an NTB, $100 bucks, and i get free alignments for a year, which is cool, because i got a freebie when i pulled it all apart to put my tokikos in.
Old Jul 28, 2008 | 08:00 PM
snowromance's Avatar
i've been lowered on stechs for about 5 months now i think. haven't gotten an alignment. nothing feels any different except for the slightly stiffer ride of course. and my tires are wearing evenly. are you sure you need an alignment?
Old Jul 28, 2008 | 08:07 PM
dibbz's Avatar
have had my s-techs on for almost a year now
done nothing but put the springs in
rotate my tires every oil change
my tires wear just fine also..
Old Jul 28, 2008 | 08:33 PM
ive been lowered quite awhile on different sets of springs with the trd suspension my wheel is slightly off to the left however i have had 3 different tires on the car and all wore evenly. i will be getting it aligned soon as im coming up on 50k miles so i want to go through all my fluids and such, make sure its all up to par.
Old Jul 28, 2008 | 09:49 PM
irelandsboy's Avatar
I installed the eibach sport line springs in about one hour and didnt have to do an alig. been riding great for over a year.
Old Jul 28, 2008 | 09:54 PM
turbotim's Avatar
First you are only on springs and dont even have a 2inch drop which is pretty much as keep'in it stop height. Second I also algn my cars when I drop them on coilovers but thats a 4-6 inch drop not 1.5 lol. You will be fine
Old Jul 28, 2008 | 09:58 PM
tCscotty's Avatar
Best thing to do is get quotes without telling them you are lowered. Then go from there.
Your camber will be slightly off, but your main consern is going to be the toe adjustment. It may not even be off because of the springs. Daily driving will mess up your alignment more than changing your springs.
$360 is f'ing robbery.
Old Jul 28, 2008 | 10:19 PM
kewlbox's Avatar
I'm on tanabes and my toyota dealer did it for 75 or 80.
And i have no uneven wear on my tires after 8,000 miles.
Old Jul 28, 2008 | 11:54 PM
TheTransporter's Avatar
Geez $360 for an alignment w/ camber kit? I lowered my box on Stechs/KYB GRX's about a month ago and did my alignment after getting new wheels and tires. I ended up paying 120.00 for my alignment w/ rear camber shims. The name of the shop that performed the work is The Line Up Shop and they are used by a number of dealerships and are highly recommended by the local mechanics in my area. Too bad they're only located here in Portland. Main difference between them and most alignment shops ii that they use pits as opposed to lifts. I've always been told to avoid the tire shops for alignments. However, firestone isn't too bad if you're on the lifetime alignment plan. Anyways my recommendation would be to either take it to Beaumont Alignment since it is they're specialty or to the dealer (or whomever they recommend). Screw the tire shop, they'll probably mess it up anways.
Old Jul 29, 2008 | 09:20 AM
hwybox's Avatar
I also went to the Scion dealer. $85 my VSC ABS CEL all came on about a week after I lowered it, they said it was just out of alignment. Do not listen to what other are saying about not gettin a alignment you can do more than tire damage, over time your trans and other suspension parts will ware and fail long before they should, and its just the safe thing to do. Dont pay over $90 for it.
Old Jul 29, 2008 | 05:13 PM
NorCal76's Avatar
My two cents... don't worry about doing an alignment unless you notice a problem. I am on Progress springs (approx. 1.5" drop) and had no problems with my alignment or tires after the install. I recently had new brake pads put on and only a slight adjustment was made to the toe angle. They (Brakes Plus) didn't even charge me for the alignment since it was so minor--either that or it was because of my good looks.
Old Jul 29, 2008 | 06:17 PM
swartzautoman's Avatar
i got mine done about 2 month after lowering it on s-techs and it was $60 for front end only, the toe was only out by a little bit, plus i had the echo struts up front.
also being lowered doesn't effect the specs anyway, at least not on pur cars anyway
tell Tires Plus to suck it because they don't know what they are talking about.
you came to the right place asking us for advice
Old Jul 29, 2008 | 08:27 PM
Sciond's Avatar
placed in correct area....
Old Jul 31, 2008 | 04:24 PM
fztcar's Avatar
hey guys. thanks for all of your help. i had the alignment done at beaumont alignment this morning. It cost me $70. Thanks for helping me make the right choice and not cost myself allot more money.
HeyyJose
Mar 11, 2015 02:15 PM
riotmonkey85
Mar 6, 2015 05:22 PM
ninja_steph
Feb 5, 2015 02:50 AM
STCxB
11
Jan 9, 2015 04:30 PM
Besk_one
Oct 16, 2003 07:45 PM
