Scion xD Forced Induction Turbo and supercharger applications...
Rear Mount Turbo
Old Aug 13, 2008 | 03:36 AM
Rods-N-Guns's Avatar
Default Rear Mount Turbo
Hi guys and gals.
Has anybody thought about or looked into rear mount turbo systems?
I have been looking at the one from Squires and I must admit that I am intrigued.
http://www.ststurbo.com/
Old Aug 13, 2008 | 06:32 AM
Zefoxe's Avatar
those tend to be more effective with v6/v8s
Old Aug 14, 2008 | 02:05 AM
pickledchang's Avatar
yeah, i imagine the lag on those with a 4 cyl would be unbearable. im not all that crazy about having the piping hanging down under that car like that either. hit a bad bump and time to call triple A.
Old Aug 14, 2008 | 02:22 AM
NotJonGreco's Avatar
If you have the space in the engine bay, why not just go for a regular set up? It will be more efficient, no worries on sucking water or anything through the turbo. Given it will be less unique, but in the long run, especially if this will be your DD, a better bet.
Old Aug 15, 2008 | 02:42 AM
Ummmm exactly. There is no room in the engine bay without major mods moving batteries and modding the headers etc. This setup is a lot easier.
Old Aug 20, 2008 | 03:19 AM
CXT's Avatar
CXT
there is a tC locally with a rear mount turbo setup
Old Aug 20, 2008 | 03:23 AM
I would love to see it. Can you pm me with any contact info (with the owner's permission of course)?
It is highly likely we will be doing a feature on the STS turbos in the first edition of HyperCarZ and I would love to include it with that feature.
Thanks
Old Aug 20, 2008 | 11:39 AM
CXT's Avatar
CXT
greg deezy i beleive his name is. There is a huge build thread somewere on this forum.
Old Aug 20, 2008 | 02:02 PM
Thanks CXT, I will try find it.
Old Aug 20, 2008 | 02:06 PM
Ace83's Avatar
Ronin Scion
the rear mount turbo kit for tc planned by strippermotorsports was unsuccessful.. it just died without any updates
Old Aug 20, 2008 | 03:29 PM
Hmmmm just tried to go to the strippermotorsports web site and it looks like they may be out of business.
Old Apr 12, 2009 | 01:38 AM
cobaltbravo's Avatar
just picked up the latest issue of S3 ( it had a tC on the cover, caught my intrest) and they have a tC with a rear mounted turbo on the cover with a detailed install spread. hadn't seen this style of turbo before, wonder what it would take to install in the D? the turbo would fit in the OEM muffler's spot, after cutting out the exhaust all the way up to the cat ( getting rid of the resonators) there might be room for the two pipes. I dont know jack about installing turbos and barely know how they work, so based off what they did with the tC, and what we know about the xD, could this be done? hopefully someone who does this kinda work could shed some light on this for us. if it did work, what else would be needed to make it happen, i.e. fuel injectors...
link to article, sorta http://www.mishimoto.com/mishimoto-s...e-14-2008.html
link to STS http://www.ststurbo.com/home
Old Apr 12, 2009 | 12:15 PM
DeathMachine's Avatar
Can it be done? Yes.
Can it be done well? Yes.
Is it efficient? NO!
Yeah this rear mount turbo thing is a great idea, but trust me, looked into this waaaaaaaay before, when I bought my xD in Sep. 07. It works good in theory, but after all the research I did and questions asked, its just not an efficient setup for a 4 cyl. The exhaust temp isn't high enough where the turbo is for it to work at peak efficiency (meaning the air isn't moving fast enough). the most you're going to get out of it is 5 MAAAAYBE 6 lbs of boost, and thats going to be at a REALLY high RPM. And as mention before the lag would be HORRIBLE on such a small 4 cyl. The charge piping is WAAAAYYY too long for it to still effienctly keep the engine boosted at the proper RPMs.
I'm not trying to be a killjoy, by all means if someone wants to do it then do it! I think it'd be a killer project! But I don't think it would be anything much more than show....
Old May 17, 2009 | 01:39 AM
JDMJim's Avatar
turbo's should be attached to the engine, not the back bumper. but that's my opinion.
Old May 17, 2009 | 01:48 AM
yeah, as creative as it is, i would think the lag would be horrible.
Old Jun 23, 2009 | 10:41 PM
TurboToyotas's Avatar
Just my 02 cents.
and to see if anyone picks up on a few things.
1. Rear mount does work. Its not at laggy as one would think
2. What about mid mount? Less piping....both ways
3. Use an Aerodyne turbo Self contained. No need for oil feed or drain. Internaly gated and does not need a blow off valve.
They cost a little more, but you are saving by not having to use the normal range of parts associated with other turbo kits.
Would use your stock header and b pipe. Then small section with adapter for turbo. Run what you want from the turbo back
Run 2" chargepiping on the hot side and most of the cold side then upsize to 2.5" before the TB for a blow through setup.
There is plenty of room for a setup like this
Be very cost effective. Not allot of work either.
Just an idea.
Regards-
Todd
Old Jun 23, 2009 | 10:43 PM
Just my 02 cents.
Just an idea.
Regards-
Todd
Old Jun 29, 2009 | 03:00 AM
DeiselFuel2o2's Avatar
yea mid mount or 1/4 mount should work well. 1/4 mount will be more at peak efficiency and you wont have to worry about your header cracking at all. yay.
Old Jun 29, 2009 | 01:26 PM
Ace83's Avatar
Ronin Scion
a nice drawing of the designs might help!
Brammi
Nov 13, 2016 03:46 AM
MRE
Feb 16, 2016 11:26 PM
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
