Would this tire work on oem sized wheels????
Old Aug 18, 2008 | 01:37 AM
kcxd's Avatar
Default Would this tire work on oem sized wheels????
If i understand the numbers correctly then this tire should work but be a lower profile correct?
195/40/zr16.
Old Aug 18, 2008 | 01:57 AM
laszlo5's Avatar
Default Re: Would this tire work on oem sized wheels????
195/40/zr16.
sure it would fit, but your speedometer would be off. when it reads 60 mph, you will actually be going 52.7 mph.
you will run up to the 36,000 mile warranty pretty fast with those tires.
Old Aug 18, 2008 | 02:10 AM
kcxd's Avatar
What is it about that tire size that I am not getting then? Why would it effect the speed and milage that way? My brother in law put on some 17's on his xb and put on low profile tires. THat situation caused no adverse effects for him what am I missing here?
Old Aug 18, 2008 | 02:48 AM
laszlo5's Avatar
to keep the speedometer true with 17" rims, you need low profile tires to keep the circumference equal to the 16" rims.
your plan is to use 16" rims with low profile tires. what you're going to end up doing is making your car look like it's on go cart tires. the secret to up sizing is to keep the circumference equal to the original tires so the speedometer reads true. low profile only works with larger rims... not equal size rims.
gettoastedinthetoaster
Dec 29, 2014 11:39 PM
TJ
10
Apr 15, 2006 05:12 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
BradinVA
Oct 3, 2003 12:50 AM
scionlife
Apr 16, 2003 05:13 PM
