Cleaning Advice!
Old Dec 16, 2004 | 01:10 AM
Synrax's Avatar
Default Cleaning Advice!
At only 260 miles, I get a nice dent, scatch, and paint marks on my rear bumper cause some a-hole woman can't drive. It was a small fender bender in the parking lot, so I won't replace the bumper. The dents suck but I can live with it. But the paint is all over. I need advice on how to clean off her paint without scratching up my car and making it worse.
Old Dec 16, 2004 | 05:16 AM
Souljah347's Avatar
you're autoparts store should have a compound for that, you'll have to rewax when your done though
Old Dec 16, 2004 | 05:33 AM
zbo's Avatar
zbo
wash the dirt off, and use clay bar, and scrape off lightly with like some sort of plastic if that doesn't work.
Old Dec 16, 2004 | 06:52 AM
miraclecreator's Avatar
my mom had this magical liquid stuff which i dont know what it is or what it's called. But u apply on the "wound" and wax it off and the skratches or marks will be gone (only light ones) It works by "removing" the orginal paint and use it to cover the wound. hope that helps.
Old Dec 16, 2004 | 07:55 AM
Thread's Avatar
First step is trying Meguiars cleaner wax.
If that doen not do it then time to get polishing compound. This will leave a haze on the pain when you get the other paint off but then go over it with Meguiars cleaner wax and it will be good as new.
If the polishing compound does not do it then try rubbing compound but be gentle at first because this is gritty stuff, then go over that with some 3M cleaner, then apply wax. Should be good as new.
Old Dec 17, 2004 | 05:25 AM
Synrax's Avatar
Alright, thanks for the tips. I'll try the clay bar first.
Old Dec 17, 2004 | 08:29 AM
eclipxe's Avatar
You should follow Thread's advice - always start with the least abrasive. Many people recommend a clay bar for everything, but they don't realize that it can take years off the life of the paint everytime you do it. The clay bar essentially removes a top layer of the clear coat. Even worse can happen if the bar is not lubricated enough when sliding it over.
Try the cleaner wax and compounds first - if that doesn't work then use the clay bar as a last resort.
Old Dec 17, 2004 | 06:38 PM
Tc808's Avatar
If you are using a detailing clay bar (vs. an abrasive one) then it doesn't damage your clear coat. I seriously doubt that you will take years off the life of your paint each time you clay your car.
Old Dec 17, 2004 | 06:49 PM
eclipxe's Avatar
Sorry, I was referring to using an abrasive clay bar (i.e. paint shop) - If used without enough lubricant, both the detail and abrasive clay bars can harm perfectly good paint.
Old Dec 18, 2004 | 03:52 AM
Synrax's Avatar
Hmm ok. Guess I'll go with the cleaner wax first then. Unless someone posts within 12 hours I might change my mind again lol
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
ScionDP
Scion tC 2G ICE & Interior
Nov 5, 2015 09:59 AM
torqueTc
Oct 8, 2015 05:39 PM
excessads
Sep 15, 2015 05:28 PM
paisatronix
Sep 5, 2015 04:13 AM
