hard to start
Old Dec 16, 2004 | 03:53 AM
TOAST3R's Avatar
Default hard to start
Has anyone else had a problem starting theirs? it seems to take longer to start than any of my other cars ive had. its winter here but i keep it in a garage and it hasnt been cold yet really either.
just feels like it takes quite a while to start. in my other car a metro i turn the key and right away its starts
Old Dec 16, 2004 | 05:01 PM
UnFocused's Avatar
Have you changed gas companies latley? I would stick to Chevron w/ technon- never have had a problem...
Old Dec 16, 2004 | 05:10 PM
ltj42884's Avatar
mine seems to take a little long to start...not a rediculous amount of time or anything...just seems to take a few seconds...maybe cause its really gettin cold now
Old Dec 16, 2004 | 05:16 PM
superjeer's Avatar
I've had cars that just don't like cold (my contour). My xB takes an extra crank or two to fire when cold, it seems. Not like cranking forever though.
Old Dec 16, 2004 | 05:23 PM
Joehnn's Avatar
Same for me. Do you think a little bigger battery would help? It did on
my last car.
Old Dec 16, 2004 | 06:44 PM
TOAST3R's Avatar
i normly use mobil. we dont have chevron around here. its either rmobil, kwik trip or clark
Old Dec 16, 2004 | 06:50 PM
superjeer's Avatar
my last car.
That could be.. low CCA could make it turn just slow enough to make a diff, I suppose.
Old Dec 16, 2004 | 07:01 PM
hmmm i dont have any prob but then again im in ca so the coldest it gets is like 30 . mine almost always starts on the first or second crank
Old Dec 16, 2004 | 07:18 PM
Joehnn's Avatar
my last car.
Yeah, mine cranks slower on cold (20 or below) mornings. I'm sure I'll be OK for a couple of years, then I may buy a more powerful battery. Crank er up baby!
Old Dec 20, 2004 | 03:25 AM
Buebie's Avatar
MN Scions
Hey man.
Well, the high here today was 4 degrees. I have noticed a real problem starting my car. I drive it everyday, and have it parked overnight for less then 12 hours. When I go to start it in the morning it takes about 6 seconds of "rur rur rur rur" Then finally, but slowly turns over with a not-so sure of itself turnover. I find this disturbing, mainly because I know its going to be a hell of allot colder. What am I going to do when its -30 degrees?
This is really the crapiest winter car I've owned, I've never seen this before. Plus this so far has been the mildest winter in history...its snowed once lol.
Old Dec 20, 2004 | 03:33 AM
jmack's Avatar
Default Takes a little longer
My TC has been taking a bit longer than what seems normal to crank over also. Always starts, but I will bet that I'm going to have problems when it gets real cold.
Old Dec 20, 2004 | 03:51 AM
jct's Avatar
jct
could be changing over to the winter blend of gas
Old Dec 20, 2004 | 03:57 AM
scion_tC's Avatar
I know the tC is equipped with an engine immobolizer, could that be the reason why it takes a few seconds to start, I own a tC and find that it takes a second or two, to fire up.
Old Dec 20, 2004 | 04:03 AM
TOAST3R's Avatar
i dont believe that would make a difference, i think an engine immobilizer would stop the starter from even attempting to run. i could be tottally wrong too, but thats how i think it would work
Old Dec 20, 2004 | 04:16 AM
dgHotLava's Avatar
to be an effective engine immobilizer it should interupt the ignition or fuel systems....
if it just did the starter , you could pop the clutch on a stick and still drive away....(provided you got passed the steering lock)
oil is thicker and clearances get tighter in cold weather, thats why it seems to take longer... the systems just work a little harder...and winter is when most cars will develop problems...
Old Dec 20, 2004 | 11:59 AM
boilerman's Avatar
Larger battery has made a difference for me in the past. A larger positive cable from the battery to the starter might help. Manufacturers will scrimp where possible.
Old Dec 20, 2004 | 07:03 PM
superjeer's Avatar
after the 0 degree morning this morning I'm conviced that you'd be ok with a bigger, meaner battery.
Old Dec 21, 2004 | 02:09 AM
mfbenson's Avatar
The original tank of gas was tough to start the car with and I only got 20.0 mpg with it too. I'm only on the second tank of gas but it seems to start more easily now. I think maybe this car is particularly sensitive to the quality of gas in it.
Old Dec 21, 2004 | 03:21 AM
superjeer's Avatar
^^^ With a high compression ratio I would think so too.
mw1957
Mar 16, 2015 06:00 PM
black2011tc
Mar 9, 2015 11:02 PM
CPL_Radar
Mar 5, 2015 05:42 AM
eatcrispycreme2
Jan 30, 2015 03:43 AM
cid_mcdp
Jan 5, 2015 02:45 PM
