ETD Question
Old Aug 29, 2008 | 10:29 PM
STNC's Avatar
Default ETD Question
Ok, I just put on my Weapon*R Engine Torque Damper, and my car seems different, but when I'm stopped and in drive, it vibrates like crazy, what could this be? Have I put it on wrong, is there something I can do with the damper?
Old Aug 29, 2008 | 10:32 PM
SquallLHeart's Avatar
is it connected right? it looks like it's gonna touch the other line..
shouldn't it be attached on the other side of the bracket where it is next to the engine?
i dunno..
Old Aug 29, 2008 | 10:42 PM
cmv138's Avatar
try some Edead on the mount . should help alittle. you will always get some type of vibration b/c the ETD is transfering the movement to the car chassis.
Old Aug 29, 2008 | 10:43 PM
STNC's Avatar
Yeah...Idk...
Old Aug 29, 2008 | 10:44 PM
STNC's Avatar
like where on it, like sandwich it? could you circle it maybe in mspaint?
Old Aug 29, 2008 | 10:46 PM
ohh... yea.. you will get alot more vibration as it is with the ETD... i was thinking more of a rattle when i answered above.
you'll have to pretty much deal with that, though a little sound dampening will help. sandwich the thing.
Old Aug 29, 2008 | 10:47 PM
STNC's Avatar
where do i put this sound dampening? am i using the paint? or the sheets?
Old Aug 29, 2008 | 10:48 PM
*edited* post above..
sheets would work better..
Old Aug 29, 2008 | 10:50 PM
STNC's Avatar
and where do i put them?
mspaint circle on area?
Old Aug 29, 2008 | 11:00 PM
dude.. so demanding...
how do you not understand sandwich? between the bracket on the strut.. and well.. the strut.
Old Aug 29, 2008 | 11:02 PM
STNC's Avatar
lol, that's what i thought! I just want to make sure!
Old Aug 30, 2008 | 03:30 AM
TylerC08's Avatar
I thought the school lost this...
Old Aug 30, 2008 | 03:31 AM
STNC's Avatar
no...they can't read,
it said my name on the package, and when she gave it to me, she was like "It doesn't have your name on it..." FOOLS!
Old Aug 30, 2008 | 04:38 AM
jetlounge's Avatar
i dunno..
yes you are right. it is too close to the ac line. it was installed improperly.
might be the cause of a little vibration.
swap it to the other side first.
also, did you adjust the length of the heim joints before installing? i have a massive post on here somewhere about installing the ingalls and setting the proper length. its on my blog somewhere too.
people always think you can just slap these things on without adjustment...
Old Aug 30, 2008 | 04:39 AM
STNC's Avatar
how do i adjust the hem lengths?
Old Aug 30, 2008 | 05:21 AM
Dr_Isotope's Avatar
1. Measure the distance between the eye on the strut tower bracket and the eye on the engine mount bracket.
2. Buy an MTB air shock of the same eye-to-eye length.
3. Take off Weapon R damper, put air damper on.
4. Throw that worthless Weapon R elastomer housing away.
5. Enjoy a rattle-free life.
Old Aug 30, 2008 | 11:28 AM
STNC's Avatar
where do i get an air damper from?
Old Aug 30, 2008 | 11:40 AM
jetlounge's Avatar
there are no rattles with a properly installed etd. but you will get engine noise transferred to the cabin.
try installing your equipment correctly, before buying new things.
it should have come with instructions, but this is my writeup on install of the ingalls. should be the same for yours.
http://blog.scionxtc.com/blogs/archi...ue-damper.aspx
Old Aug 30, 2008 | 11:44 AM
STNC's Avatar
The person I bought it from looked at this thread and said i installed it correctly, are there any pictures of an installed weapon r?
Old Aug 30, 2008 | 04:27 PM
jetlounge's Avatar
dme and ingalls both have the heim joint closest to the engine block on the right side of the bracket....away from the ac lines. i don't know why you would place yours closer.
and adjust the heim joint length. if you just slapped it on this is the reason for your intense vibration. read the writeup i posted above. adjustment technique will be the same.
