trouble starting car
Old Dec 17, 2004 | 06:17 AM
0605's Avatar
Default trouble starting car
has anyone had trouble starting their xb??
the other day the key wouldnt even turn...like it was stuck or something!
does anyone know what may have caused this?
...i have the scion security system if that has anything to do with it but the alarm was not going off.
Old Dec 17, 2004 | 07:56 AM
sometimes the sterring wheel will lock to hard so you have to turn it harder for the key to move.
Old Dec 17, 2004 | 06:26 PM
erichlf's Avatar
My xB Auto does not like to start in the cold. Have to hold the key for a few seconds.
Old Dec 17, 2004 | 06:40 PM
Reno's Avatar
my manual xB doesn't like to start when its cold. it sounds like it is struggling to start.
Old Dec 17, 2004 | 06:49 PM
Sciond's Avatar
and you have push the clutch through the floor
Old Dec 17, 2004 | 09:28 PM
05camoxb's Avatar
Default Re: trouble starting car
yeah happened to me twice already.. as stated, the steering wheel locks tightly sometimes... just turn the key harder than you usually do and it should unlock.
Old Dec 17, 2004 | 11:11 PM
Maybe you should take it back to the dealer to see if the mechanism needs a little lube in there.
Old Dec 18, 2004 | 08:42 AM
hou8389's Avatar
i have dad the same problem starting when it is cald. i even had it not start at all once. i took it to the dealer and they told me there was nothing wrong and they had no clue. i do have a system in it and they sad it was it. i later want and got someone else to look at it and they sad it was the battey and not the system but the system did not help. i even had a cap. so today i am adding another battey and replacing the stock one too. i hope that fixes it.
Old Dec 19, 2004 | 08:37 PM
Craig_X1's Avatar
Don't just turn the key, this is a safety feature, turn the steering wheel while turning the key as stated before, that should free it. If you force it, you are risking damage.
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
BV19869
Dec 11, 2014 06:05 PM
rcflyer15
Dec 5, 2014 05:15 PM
tC_Normo
Oct 22, 2003 07:20 PM
