n/a power questions
Old Dec 21, 2004 | 12:37 AM
slimXB's Avatar
Default n/a power questions
i already have the injen CAI and a greddy evo II cat back , i was looking at the hp racing header to do next but what after that?
what other bolt ons are readily available with out doing internals
any pulley systems or or intake manifolds yet?
what about plug wires and other stuff along these lines
all help and info is greatly apprieciated
please post websites that carry these options as well ... please
Old Dec 21, 2004 | 01:07 AM
dgHotLava's Avatar
do the header....
you can bolt on trubos or superchargers with out doing internals...but those are not n/a
pulleys will not increase HP only reduce rotational mass (might make it feel faster by letteing the HP reach the pavement better)
better cluth and lightweight flywheel will help...
no wires to do as this is a direct ign. system (indivual coils at each plug)
you could do a light spray of NO2 (don't know if you call that n/a or not)
Old Dec 21, 2004 | 02:02 AM
mahalzkita28's Avatar
after you get your header you can do a fuel pressure regulator too
Old Dec 21, 2004 | 02:12 AM
hahaitzskippy's Avatar
fuel regulator, pistons, headers, bigger throttle body or ITB's, clutch, flywheel, CAI, valves, valve springs, cams, cam gears, cams regrind, higher octane
lighter driveshaft, stroker kit?
Old Dec 21, 2004 | 11:49 AM
dgHotLava's Avatar
some of those dont apply to the question asked tho....
no internals......
so you are left with TB or ITB's, and better fuel...
he already has a CAI...
clutch and flywheel don't make HP, but the help it get to the pavement better. and get better throttle response....
Old Dec 21, 2004 | 03:30 PM
but pistons are a basic internal bolt on.
Old Dec 21, 2004 | 03:44 PM
dgHotLava's Avatar
you said the magic word....internal...
and there is prep work to be done before a set of pistons can just be tossed in there....
and as far as a basic bolt on, that would include a motor swap....
if you have to take the valve cover or oil pan off, it's internal....
Old Dec 23, 2004 | 02:03 AM
slimXB's Avatar
who makes cam gears , pulleys , throttle body , for us?
Old Dec 23, 2004 | 08:51 AM
aarontrini85's Avatar
i thought aluminum fly wheels incresed low end tourqe becouse they need less to get them selfs spinning
Old Dec 23, 2004 | 02:11 PM
dgHotLava's Avatar
kinda the right idea.
its not because its aluminum, they are just lighter weight (read less mass or material)
they don't increase low-end torque, they increase throttle response by reducing rotational mass....
Old Dec 23, 2004 | 03:15 PM
toyota_scion_tc's Avatar
throttle bodys help just dont go too big on n/a it will hurt you.
Old Dec 23, 2004 | 08:27 PM
kyleb350's Avatar
A lightened flywheel reduces the weight in the drivetrain thus reducing the amount of horse power/torque loss from the flywheel to the wheels. So, I guess the same could be said if you put lighter wheels on your car.
Old Dec 24, 2004 | 03:42 AM
dgHotLava's Avatar
true...
Old Dec 24, 2004 | 04:29 AM
jlaznlover's Avatar
if i were to go NA on the tc. would add an intake, axle-back(which you already have), header, fuel system upgrade, lighter flywheel, clutch, pullies and re-map the ecu to start. although most of these parts are not availble for the tc yet. so, you might have to wait a little while longer.
Old Dec 24, 2004 | 04:50 AM
dgHotLava's Avatar
i don't think you can re-map a toyota ECU....
but the rest is all good...
Old Dec 24, 2004 | 05:09 AM
jlaznlover's Avatar
you can't? :?
bootlgr
Jan 26, 2016 01:22 AM
That_Kid_Ju
Jun 26, 2015 10:57 PM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
