Rear rotor seized on, any ideas?
Old Nov 26, 2008 | 05:17 AM
SighOnTeeSee's Avatar
Default Rear rotor seized on, any ideas?
So I was trying to get my rear rotors off to put on my nifty new slotted rotors, but I spent about 40 minutes just trying to get the damn thing off and it won't budge. Any suggestions on what I could do to loosen it? I heard that the little screwhole on the front is used for this but I can't figure out what size I would need to fit it.
Old Nov 26, 2008 | 06:31 AM
Thorium06's Avatar
release the e-brake
Old Nov 26, 2008 | 03:24 PM
davedavetC's Avatar
lol
yea take the ebrake off, and smash it with a sledge hammer
Old Nov 26, 2008 | 03:25 PM
Thermos2003's Avatar
A huge rubber mallet may be a little more practical in case you want to sell the rotors or whatnot.
Old Nov 26, 2008 | 04:20 PM
I did take the ebrake off, also tried the rubber mallet, got nothin. Is there anything else I could try or should I just keep at it?
Old Nov 26, 2008 | 04:24 PM
CHPRBOX8's Avatar
since you are in chi town you have road build up just spray the poop out of it with some wd-40 and let it sit then try the rubber mallet agaion
Old Nov 26, 2008 | 06:29 PM
adg016's Avatar
If you put the wheel on, and try to spin the tire, does it at least spin freely?
Old Nov 28, 2008 | 10:14 PM
BZinn1's Avatar
if your ebrake is off and the rotor spins freely you have rusty build up between the rotor and the hub.....soak it with WD and hit it with ahammer.It will come off.
Old Nov 28, 2008 | 10:28 PM
davedavetC's Avatar
a rubber mallet wont work, you need a solid hammer (big one) and smash the sht outta it (seriously)
Old Nov 29, 2008 | 02:09 AM
s4bones's Avatar
Default yeah
e brake and is there a bolt to "thread out" the rotor?
Old Nov 30, 2008 | 07:42 AM
XIEmperorIX's Avatar
Default Re: yeah
umm..no..like everyone else..wd40 and a good beating from a mallet..hit that thing like a red headed step child!
haha i kid i kid...
Old Dec 12, 2008 | 02:05 AM
Ryan99FL's Avatar
Scion Dynasty
if it is stock rotors there should be two empty bolt holes which will accept 12x1 or 14x1 (forget!) bolts that you can torque it off with... just make sure to alternate tighting the bolts so you don't jack up your bearing...
Old Dec 12, 2008 | 04:15 AM
mattieg's Avatar
PB blaster will soon be your friend. Use that. Just make sure you dont get all that junk on your pads.
Old Jan 21, 2009 | 06:14 PM
Tofu_Racer's Avatar
There is a tool for the two small screws in the rotors. I got a tool from ACE hardware called a Harmony Puller Tool. You use this device also to pull out other car parts like the steering wheel.
Old Jan 21, 2009 | 07:49 PM
Andrew1782's Avatar
THere is a screw that attaches your radiator to the front of your car. Easy to see when you open the hood. Remove it and thread into the screw hole till you hear a loud pop....and walla all done!
Old Jan 25, 2009 | 05:04 AM
bennyboopy's Avatar
BFH or your foot with a nice boot on. Keep kicking till it comes off. Just be glad its not old school drum brakes on a solid axle. I had to use a torch once to loosen one on my Jeep.
Old Jan 25, 2009 | 06:36 AM
lol considering the OP posted this a couple of months ago i would hope they managed to get that rotor off
TotalChaos
Apr 7, 2015 09:02 PM
daniinpitt
Apr 4, 2015 08:07 PM
kleecker
Jan 2, 2015 08:09 PM
ScionDP
Dec 3, 2014 02:05 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
