Why our cars idle at ~600 rpm ?
Originally Posted by dgHotLava
you can have the car idle at redline.
it idles at a rpm that smooth. any lower it would feel like it will stall
it has to deal with inertia....
if i dont get/have a ground kit would that also be hurtful to the car then? or would it be just something that would be hp robbing?
Originally Posted by ayS
Originally Posted by timinaz
Mine was around 800 until I did a ground wire mod now it is lower.
there is a set screw on the throtle body that will adjust the closed position of the butterfly.
the ecu will detect the air flow and have the injectors mix in the proper amount of fuel.
keep the butterfly open more the idle will go up.
close it and the idle will go down. if you turn it down too far the car could stall if the A/C turns on....
IC. Let's recap, I guess, at 600 rpm is the minimum level that the car doesn't stall, even if the AC is on. Thanks for posting
My car's idle very steady around 600-700 even when I change from neutral to drive. Ground wires make that happen
my car idles' up and down sometimes...is that something with the ground/electrical?
well idle is all how your cam is if u have a big lumpy cam like i have in my v-8 car it does not want to idle low but our cars have like what i like to call truck cams they are not lump they make it have a good idle and good power band and if u notice scions dont rev all that fast too that has to do with the cam but with my v-8 car it revs quick its all has to do with the cam but yeah your car is fine if it idles at 600 my does to when it warms up so all in all your fine
Technical Service Buliton, its somthing released by Toyota that there is a problem and it has the fix.. if you take your car to the dealership and tell them what its doing, firt thing they do is look up the TSB to see if its listed..
cid_mcdp
Jan 5, 2015 02:45 PM
minter66
Dec 15, 2014 01:45 PM
