Need advice on rims... still
Old Feb 25, 2009 | 01:13 AM
mattieg's Avatar
Default Need advice on rims... still
Well you guys know tons more about rims than I do so here it is. I have been thinking about picking these O.Z. ultraleggera rims up after I get my tax returns.
Offset: 48mm
Backspacing: 6.41"
Bolt Pattern: 5-100
Rec. Tire Size: 215/45-17
Weight: 17.0lbs.
What do you guys think of them? Are they a decent rim? And do you have any other suggestions.
Old Feb 25, 2009 | 01:19 AM
O5_TRD_tC's Avatar
offset is bad
Old Feb 25, 2009 | 01:23 AM
Big_Bird's Avatar
way bad
Old Feb 25, 2009 | 02:19 AM
mattieg's Avatar
whats so bad about it? Now I tried reading about rims and offset and such, but I need all the help I can get.
Old Feb 25, 2009 | 02:21 AM
Ro_Ja's Avatar
You want an offset closer to 35.
Old Feb 25, 2009 | 02:23 AM
mattieg's Avatar
I will also be on H&R coilovers, so I do not want rubbing.
And can a spacer help out with the offset in my favor?
Old Feb 25, 2009 | 02:24 AM
Ro_Ja's Avatar
Spacers lower the offset, which makes a wheel more flush with the fenders.
Old Feb 25, 2009 | 02:25 AM
mattieg's Avatar
So with this 48mm offset that is on the rim will it stick inside the wheel well?
Old Feb 25, 2009 | 02:26 AM
Ro_Ja's Avatar
Yes. The placement will look similar to stock wheels.
Old Feb 25, 2009 | 02:28 AM
mattieg's Avatar
Well that isnt bad then I suppose. What type of spacer and offset would you recommend?
And the rim itself is of good quality correct. You can bash if you want to lmao.
Old Feb 25, 2009 | 02:32 AM
Ro_Ja's Avatar
Find something closer to 40. It'll look better, but they're still tucked in.
OZ wheels are good. I'd rock 'em.
Old Feb 25, 2009 | 02:33 AM
mattieg's Avatar
Damn, I fell in love with those rims lol.
Old Feb 25, 2009 | 02:34 AM
captainlaziness's Avatar
Agreed on the offset. Those are some light weight wheels.
Old Feb 25, 2009 | 02:36 AM
mattieg's Avatar
So how big of a spacer would I use to make it look a little better. Im sorry for the questions guys im new to the tire game, and you guys are the best to ask.
Old Feb 25, 2009 | 02:39 AM
mattieg's Avatar
Maybe a staggered fit. A little wider in the front than in the rear?
Old Feb 25, 2009 | 02:41 AM
Ro_Ja's Avatar
I'd recommend 15mm, but I don't trust such large spacers. Just get wheels that fit or put a 5mm on there.
Old Feb 25, 2009 | 02:56 AM
mattieg's Avatar
Ro_Ja would you recommend a tire similar to the OZ that I mentioned above?
Old Feb 25, 2009 | 03:02 AM
Ro_Ja's Avatar
I'm presuming the wheel is 17x7 or 17x7.5. Either way, the recommended tire size is fine unless you want larger tire (225's).
Old Feb 25, 2009 | 03:06 AM
Checho's Avatar
i had actually really considered these rims before my raderwerks, for the price you can get something much better (If they are still 300+ on Tirerack)
Old Feb 25, 2009 | 03:11 AM
mattieg's Avatar
ya 263 a rim now.
