Please help...no clue on wheels/tires?
Old Jan 7, 2005 | 03:15 AM
Jmarks1998's Avatar
Default Please help...no clue on wheels/tires?
I have no clue what offset is or what diff numbers on tires mean but I am looking to get new rims and tires. Here is what I want and maybe someone can help me out. I have a stock xB and am NOT going to lower it. I just want to get some 16's without any rubbing or rough ride. I would like a nice looking size tire on the rim though but not a real low profile. Can someone tell me what ideal rim size like lug and offest to look for and what tire size to llok for as well. Like I said I just want a 16 inch rim with a basic tire no low low profile and its NOT getting lowered. Thanks for anyhelp guys.
Old Jan 7, 2005 | 03:53 AM
DJ_X_Trodinaire's Avatar
check out the FAQ
https://www.scionlife.com/forums/viewtopic.php?t=348
Old Jan 7, 2005 | 05:13 AM
Jmarks1998's Avatar
I have read that before and it still makes no sense to me sorry.
Old Jan 8, 2005 | 02:01 PM
Jmarks1998's Avatar
Like I said I read the sticky and still am very dumb when it comes to wheels and tires. I found the specs to the wheels I like and am wondering if someone can help.
Here is my goal again:
Here is the wheel measurement: 16X7 4-100/114 42
What would I need to make this sit somewhat flush with the sides of the xB?
Can someone match up a nice size tire that isn't too low profile but not a n ugly look that would still ride nice. Thank alll.
Old Jan 8, 2005 | 06:42 PM
PandaIst's Avatar
you could always add rear spacer shims from one ton garage so the rims are more flush to the rear fender.
Old Jan 8, 2005 | 08:10 PM
TheScionicMan's Avatar
The bolt pattern you want is 4 X 100
42 offset will look very sunken. Like pandaist said, get the rear spacer shims from Van at OneTonGarage: http://onetongarage.com/products/rea...him/index.html
That will add almost 10mm to the rear .
As for tires, it looks like people are running 205/40 to a 205/55, with someone with a 7.5 width running a 215. The first number refers to the width, the 2nd the sidewall height - the lower the number the lower the profile.
Hope that helps...
Old Jan 8, 2005 | 08:17 PM
Jmarks1998's Avatar
So by adding the 10mm shim would that basically make it like a 32mm offset essentially instead of a 42mm.
Old Jan 9, 2005 | 12:27 AM
yes, basically.
Old Jan 9, 2005 | 01:47 AM
Jmarks1998's Avatar
So only spacers on the rear? would the fronts look ok without them, will they sit flush already?
Old Jan 9, 2005 | 04:23 AM
The front has a wider track than the rear. If you need more in the front, you can use wheel spacers. You can probably run a 3mm OK, more than that and you'll need to get longer wheel studs. Same goes for the rear if you need more than the shims.
roxpeaches
Oct 6, 2015 01:59 PM
scionlife
371
Jun 2, 2015 11:00 PM
mvez
Scion tC 2G Wheel & Tire
Apr 1, 2015 12:37 AM
beckysuemomof2
11
Oct 17, 2004 05:31 AM
jimsxb
Aug 6, 2004 06:33 PM
