A/F Ratio 15.9 .... HELP!
Old Feb 27, 2009 | 01:48 AM
bridfi's Avatar
Default A/F Ratio 15.9 .... HELP!
for those of you that dont know...
i put an 08 xb engine in my 05 tc w/05-06 trd s/c kit w/NST 9.5 psi pulley, w/05 tc ecu and trd reflash.
just got it started today, and my A/F ratio bounces around, at idle its around 15:1 and w/a little bit of throttle, it hits 16 and even bounces up off the gauge's limit which is 17 i think...
averages about 15.9
what do you guys think?
faulty gauge/sensor?
could the increased compression of the engine not be compatible with the ecu how its tuned?
please, all input is welcome.
(Please no questions about why i put the engine in, where i got it, etc, only post relevant to this post. Thank you.)
Old Feb 27, 2009 | 01:53 AM
Ace83's Avatar
Ronin Scion
are the lean mix during off throttle or high vacuum? how's the boost afrs? if boost afrs are lean too, you might need more fueling or tuning.. you have big injectors too?
Old Feb 27, 2009 | 01:56 AM
tC_2NeR's Avatar
from what i read in ur post it seems u have an 08 engine with an 05 ecu
theres ur problem...
the 08's are different than the 05-06's
Old Feb 27, 2009 | 01:58 AM
bridfi's Avatar
well my boost gauge is showing 4 psi at idle and about 20 under a little bit of throttle, i dont think thats working right, dont have the slightest idea why. the A/F ratio is my major concern, but i really should get the other 2 gauges working as well maybe this is a problem my boost gauge can let me know also...
it is a completely different ecu though thats made for the 9.6:1 compression ratio engine, not the 9.8:1 c/r newer engine, i dont know if that has anything to do with it or everything to do with it..
there is definately alot i need to figure out, i am running the TRD supplied injectors.
Old Feb 27, 2009 | 01:59 AM
bridfi's Avatar
okay, thats what i was kind of thinking, dammit.
any other suggestions are welcomed...
Old Feb 27, 2009 | 02:02 AM
Ace83's Avatar
Ronin Scion
its doesnt sound right, 4 psi on idle? are you sure its not vacuum? seems to me like its a vacuum reading not psi..
Old Feb 27, 2009 | 02:04 AM
unxpectederror's Avatar
not only would the compression be off but the cams are different too. you now need a 07+trd tune
Old Feb 27, 2009 | 02:06 AM
bridfi's Avatar
im new to this gauge, it says 4, wouldnt it have a -4 if it was vacuum?
didnt realize the cams were different, i tried to research as much as i could before i attempted this, but couldnt find much documentation....
Old Feb 27, 2009 | 02:07 AM
bridfi's Avatar
im probably going to end up getting a stock 05 ecu to match up with my harness and just get it tuned with the aem f/i c
Old Feb 27, 2009 | 02:09 AM
Ace83's Avatar
Ronin Scion
what kind of gauge you have.. my old aem gauge doesnt display negative values.. anyways the reflash should have something to do with it..
Old Feb 27, 2009 | 02:14 AM
bridfi's Avatar
i have the aem boost gauge the one that goes from -30 to 30 psi
Old Feb 27, 2009 | 02:18 AM
Ace83's Avatar
Ronin Scion
i didnt know the aem boost gauge goes up to -30.. the lowest ive seen is 22.2 vac.. but i have the truboost
Old Feb 27, 2009 | 02:29 AM
bridfi's Avatar
so that gauge is 100% correct no doubt about it?
(i mean the a/f r gauge)
Old Feb 27, 2009 | 02:34 AM
Ace83's Avatar
Ronin Scion
hard to tell.. you feel poor performance while driving normally? just to let you know off throttle/deceleration/high vacuum (20 up on aem boost gauge) could show lean numbers 15 to -- but should settle back close to 14.7 when back to idel
Old Feb 27, 2009 | 02:43 AM
bridfi's Avatar
i havent driven it yet...
i was figuring with the s/c it would be under 14. is that true? im just assuming...
Old Feb 27, 2009 | 02:54 AM
OC3RULZ's Avatar
OhioScions
First off Idle of 15.9 is alittle high but nothing to worry about, however pressing the gas and it going up is.
You need to take it to a Dyno and have them put there Wideband on it and check to see if your AEM A/F is calibrated. Did you calibrate your A/F gauge b4 you started the car?
Also which MAF sensor are you using?
Ace83's Avatar
Ronin Scion
what you need to monitor is the a/f in relation to load (vac/boost).. you should be close to 14.7 on vacuum (cruise) as you approach boost pressure afr should become richer.. i would try driving it as the ecu will adjust your fuel trims.. just dont go boost and drive it slowly and see if they will eventually get better.
Old Feb 27, 2009 | 02:55 AM
bridfi's Avatar
callibrated gauge? no... didnt know i needed to.
Old Feb 27, 2009 | 02:57 AM
bridfi's Avatar
the '05 tc maf sensor. i figured the other one would have different voltages that would confuse the ecu.
OC3RULZ's Avatar
OhioScions
Yeah there is a sequence that you should do. I am not sure what your AEM entails, but my Innovate requires a calibration before you start the car.
