A/F Ratio 15.9 .... HELP!
well...
re-miced the bearings and housing, they are a perfect fit. i think i measured wrong the first time. its still rattling at idle. i dont know what the ____ to do anymore.
is it because of the polyurethane motor mount inserts??
i still have a oil leak and coolant leak..
im seriously getting fed up with this pos.
The aem wb gauge self-calibrates. Its not like the innovative wb, or some of the others out there.
I have polyurethane motor mounts, and at idle the car does shake more than normal, lol. Once the car is in movement, its very smooth.
Originally Posted by OC3RULZ
Can you tell where the oil leak is coming from?
Same with the coolant?
coolant is leaking on the tranny from drivers side of head, checked lines that go to the heater core and they are extremely tight.
for the oil leak check your crank seal. had one go bad on me and it poured oil out. cheap fix and relatively easy. for coolant leak, check the throttle body. the xa xb is a cable driven TB and different from the TC fly-by-wire, but I believe yours has coolant in and coolant out. Also check the thermostat housing too.
you know what i didnt even think about the tb. i thought it was the heater core, ill check that today.
thermostat housing is up front and its sealed tight.
i replaced the crank seal myself on the engine, ill double check it, maybe i dont have it in correctly. i have royal purple oil all over my pullies, belt, p/s pump, pretty much everything on that side of the engine bay is covered in oil. but its only when im on the throttle, driving it around. its not leaking at idle, maybe because the pressure is higher, i dont know.
as for coolant def check the TB, prolly a leak in the line if its not tightened.
GREAT NEWS
just to finish this thread off, ive been working on the car all day and...
FOUND THE LEAKS
oil was coming out from the pulley side of the valve cover, gasket was ____ED up severely
and the coolant leak was from the T coming from the head, it was the hose on the part that you can barely see, the clamp was never tightened down,
got my bumper back on today, after my valve cover gasket comes in tomorrow she'll be back on the road in full force!
YAY
FOUND THE LEAKS
YAY
BlingSlade
Oct 19, 2016 12:39 AM
