another exhust size Q???
Old Jan 7, 2005 | 04:43 PM
jct's Avatar
jct
Default another exhust size Q???
how do you messure exhust pipe size is it diameter or circumference
Old Jan 7, 2005 | 04:47 PM
BoostedRex's Avatar
diameter.
Zach
Old Jan 7, 2005 | 09:42 PM
showpaojoe's Avatar
IV ACE
Doesn't matter...the shop you go to should be knowledgeable enough for you not need anyone elses input.
Old Jan 7, 2005 | 10:19 PM
damn joe. harshness. lol but yeah its diameter. stock is 2in from cat to resonator and then 1.75 from resonator back.
Old Jan 8, 2005 | 01:16 AM
jct's Avatar
jct
damn why does it go so small after the resonator that sucks
so i should replace the resonator with a 2inch in and a 2inch out and a 2inch all the way back with a 2inch in muffler so pretty much a cat back system hmmmmmm
might have to goto my local muffler shop and find out
Old Jan 8, 2005 | 01:24 AM
showpaojoe's Avatar
IV ACE
If from the cat to the resonator was 2"...then there would be no more reason to buy anything more than an axle back since having 2" complete piping is MORE than enough for a 108hp car.
Old Jan 8, 2005 | 01:58 AM
The pipe size is what helps the motor have great gas milage. It really is a wierd design, but none the less our cars are special like that.
Old Jan 8, 2005 | 02:16 AM
jct's Avatar
jct
so the best and safest bet is just go with an axle back set up
Old Jan 8, 2005 | 02:18 AM
depends on what you want. A catback is a good way to go, but than again so is an axle back. :D
Old Jan 8, 2005 | 03:00 AM
jct's Avatar
jct
i want to keep my mpg the same or improve it while gaining a little better sound and proformance
Old Jan 8, 2005 | 03:25 AM
Fujiz_xb's Avatar
Old Jan 8, 2005 | 10:43 AM
ummm yer mileage shouldnt drop with 2.0 inch if it was 2.25 or 2.5 then it could hurt it but only cuz u would lose torque thus makin u rev higher equaling ____tier mileage. and the 1.75 to me seems to be more along the lines of cheaper , easier , and quieter. but then wadda i no
Old Jan 10, 2005 | 04:24 PM
Than yes you might want to purchase an axle back if you really want to save mpg.
Old Jan 10, 2005 | 05:12 PM
mikochu's Avatar
The piping from the cat to the resonator is 2"? I could've sworn it was 1.75"... hrmmm... Makes me want to take a piece of string and measure...
Old Jan 10, 2005 | 05:27 PM
jct's Avatar
jct
do it
Old Jan 20, 2005 | 09:43 AM
bB384's Avatar
IV ACE
I would assume its 1.75 after the resonater because the resonater creates back pressure, and less (volume) air is moving out of the resonator as it did when it was moving in the resonator.
Old Jan 20, 2005 | 09:46 AM
everything before resonator is 2.0 everything aft is 1.75
rain7905643
Mar 14, 2015 12:48 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
meechindisbeech
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
