alignement kit for xb
The mac struts are pretty much straight up and down along its line of travel, so whatever amount of drop you do, you really don't need any camber adjustment. You'll primarily deal with the toe and such.
Now, if you need clearance due to wide wheels, or drive somewhat aggressively, you may want 2 degrees of camber up front.
But as a daily driver, everyday car, and for a car to commute in, the factory settings are more than adequate.
Good timing.....
I noticed that my front wheels are starting to sag recently. When I read your comment about driving aggressively, and needing 2 degrees of camber. I guess that is the problem. I barely know anything about that. I drive aggressively to balance out the slow speed of the xB. So, any more details would be appreciated because im not that knowledgeable.
Anytime I do suspension work, or get a different set of tires/wheels, I get an alignment. I much prefer paying $40-60 for a 4 wheel alignment, than $230+ later for replacing two tires.
eatcrispycreme2
Jan 30, 2015 03:42 AM
kleecker
Jan 2, 2015 08:09 PM
minter66
Dec 15, 2014 01:45 PM
Besk_one
Oct 16, 2003 07:45 PM
