getting the oil bolt out
hi there
i have to change my oil cause its dirty and was trying to get the bolt out and it wouldnt budge i try wd-40 pam and other stuff......if there any tricks on getting a tight bolt out..
its easy to reach but that sucker wouldnt come out and i know how to replace oil but this is my first time for this car and i wanted to try myself
any suggestions..should i try harder i dont wanna pull the oil pan off if i try to hard
Just try harder. Sometimes those things are on there really tight, like 100ft/lbs tight. Also, don't forget to replace the crush washer. I have seen someone run an engine dry because they didn't replace it and the oil plug actually vibrated out.
yea i just need to be in a good position to where i can have enough strength to get it out...
i wasnt really trying hard i mean i was putting some force to it but not enough just have to try again if worse comes to worse il have my buddies take a look at it see what they can do cause i do know as you said it can be really tight but it should only be hand tight
Just get a decent sized socket wrench throw a 14mm on that sucker and turn it off. If that doesnt then take a bar or a jack bar and put it over the wrench to get more leverage and pull it off...
Take a flathead screw driver and stab the filter through the side, but make sure you have the oil pan underneath. Then with it in just turn.... Or just put on a batting/mechanic glove that has rubber grips on it and turn... Theres server ways bro.
any tips on getting the oil filter out i dont have a tool for it should i get one or it should unsrew right out
To get the bolt out, try a longer ratchet and a big hammer. Had to do that the first time I changed my oil. If you plan on changing your own oil from now on, I recommend the filter tool, it was about 7 dollars from the dealer when I got mine bout a month ago.
i got it out all done i just needed to pull a little harder came out..i used rachet and a 14mm socket thats all......i had gloves on this time so i think that made a better grip..
I borrowd the oil filter tool from my neighbor made the job so much easier then plieers or puching a hole on the side to messy..
so guess someone can lock this thread
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
SpaceCaptain
May 11, 2015 06:24 PM
kleecker
Jan 2, 2015 08:09 PM
