Taillight mod idea
Old Jan 13, 2005 | 05:51 PM
THE_DON's Avatar
Default Taillight mod idea
Ok, Here's what I've been meaning to do for some time now, and I want some opinions...
I want to open the stock taillight and smoke the red reflector... As opposed to smoking the whole light, just the red stuff in there... That way it's still clear, with smoked/black reflectors inside to match the BSP.
What do ya think? Is it hard is it to open the housing? I heard it's not glued shut, just snapped... Maybe a photoshopper can give me some foresight on how it would look?
Peace
-THE DON
Old Jan 13, 2005 | 06:03 PM
wyldkard's Avatar
I considered doing this exact same mod some time ago. Let me know how it works out for you....and take some pics.
-Z
Old Jan 13, 2005 | 06:45 PM
Max2k's Avatar
I painted the area behind the reflector black. Check it (you can see behind the clearguard thing:
Old Jan 13, 2005 | 08:54 PM
THE_DON's Avatar
That's nice... I'm gonna try it out... I hope I don't break my tails trying to open them!
Hey Max2k, once the housing is open, are the reflectors and red brake light covers easy to remove and put back? Or are they glued down?
Thanks
-THE DON
Old Jan 13, 2005 | 09:53 PM
Mr_scion's Avatar
N.G.S.O.
what is the e-z way to open the tail lights?
Old Jan 13, 2005 | 09:59 PM
Max2k's Avatar
To open the tail lights:
1. Remove from car.
2. Remove the bulbs and circuit strip thing
3. Stick them in the oven for 5 minutes at 250 degrees
4. While wearing thick gloves (the plastic gets damn hot!), use a flathead screwdriver or other such impliment to pry up the tabs on the top of the tail lights, starting with the outer ones and then doing the inner ones. The outer edge should pop out all at once, then pull the tabs on the inner ones up one at a time and rotate the lens upward, releasing the bottom tabs.
"Outer" refers to the edge away from the hatch and vice versa.
The Don: they're quite easy, but you have to break a small piece of plastic to get the reflectors loose. Fortunately you can just glue it back down with hot glue.
Old Jan 13, 2005 | 10:04 PM
THE_DON's Avatar
WOW
That's a little harder than I thought!
-THE DON
Old Jan 14, 2005 | 12:43 AM
Max2k's Avatar
It's actually not, you just heat it up and pop the little tabs up. It's pretty self explanatory when you're actually looking at the tail light.
Old Jan 14, 2005 | 08:19 PM
Mr_scion's Avatar
N.G.S.O.
thx
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
sciontcguy15912
Mar 24, 2015 12:36 PM
blue_xB_23
Mar 20, 2015 07:39 PM
mdhyre
Dec 7, 2014 12:52 AM
