4 wheel disc brake conversion
Parts list
Hubs from the corolla
Master cylinder. Its bigger and can handle the load from 4 calipers
Calipers and rotors
Not sure about the axles being the same size, but if they are, it will be easier to swap them out since the hubs are already mounted to the corolla ones.
Its a somewhat time consuming task. I helped a friend do a job on a civic hatch and put 300ZX brakes on a 240SX.
I know there are more things you need, but that is all I can think of off the top of my head.
Calipers and rotors
Better tires would go a whole lot further per dollar towards reducing your braking distance. If fade is a problem, racing pads would be a better first step than rear discs. Adding rear discs would be a ways down that list. I'd only do it if I were racing, and I wouldn't be doing that in an xA.
Econobox: It's not always about stopping, sometimes it's about style. And of course some of us do race our xA's. We just dont expect to pull 12's in the 1/4 mile.
ScionGunner: If you are looking for which rear brakes, try 93-97 corrolla I belive they are the right ones.
Oh and to add to RHDVIPbB's list, You May wish to change to proportioning valve but as they only have a weight difference of less than 100lbs it prolly wouldn't make a difference.
OR if you want to be completly accurate and safe about the whole issue check out This Page Here If you read under Travelling stability
you will see where they now have and Option package in Japan with Rear Disk Brakes, Thats the route I am going to go.
Just need to make that long distance phone call to a Japan service Department and pay Boucoup for it, but it will be true JDM
evolving_machine
Oct 21, 2023 01:16 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
